Results 1 to 4 of 4
Thread: Clicking noise - MK5 2.0FSI *Not typical*
    Mar 2019
    Point Cook
    Hi,
    I know what these engines should sound like and although louder than others due to direct injection there is a non-typical noise.
    It is coming from the front drivers side. While warming up on idle there is a distinctive click (sounds like on off). When getting rpms up it isn't there or can't hear it. Once warmed up it seems to be gone.
    What could this be ? I tried using mechanics stethoscope to pinpoint but hard to tell.
    Anyone have any suggestions ??
    Does it sound like its coming from in the engine? I had an issue with my TDI where the alternator pulley needed replacement. A heap of noise was coming from around the tensioner and once the alternator pulley was replaced - voila! noise was gone.
    Apr 2010
    granville, sydney
    timing chain tensioner? located under the rocker cover on the opposite side of the timing belt
    cw.mkv.gti.034ms,s2+
    Mar 2019
    Point Cook
    Thanks for the replies. If it is the timing chain tensioner will it be at a consistent time apart - this seems random time. It is more from the side of the timing belt I think ...but it is click on and off until the engine warms but doesn't seem consistent time between clicks ...
