Originally Posted by
Idle
It should, but might not — any break ought to be where the wires actually flex, and may not be obvious.
Look for signs of unevenness or heat marks in the insulation — if you find any, tug at that point and see if it will stretch a bit.
If it does, the wire is likely to be broken (note that the broken ends will make intermittent contact until the ends burn away a bit.)
If you have problems with driver door lock, check wires in black rubber grommet between the door and chassis.
2005 Golf V 2.0TDi DSG U/Grey S/roof - SOLD
