Results 1 to 10 of 20
Thread: Central Locking woes
    May 2012
    Hoping you guys can help me out with some troubleshooting here ...
    For 6 months + neither of the remotes for my central locking have worked. Started out just one not working - tried changing the battery with no luck and after a period of occasionally needing two tries to work, the second one stopped completely as well. Had to unlock with the key in the door.
    Scan of the car gives error code 00470 - Combination comfort Databus in single wire mode. Sporadic 011 - open circuit.
    Basically it means there is a dodgy connection/wire somewhere in the comfort Can Bus. However the comfort can bus is supposed to work with only one wire, so not convinced this is the cause of the problem?
    And today, I noticed the central locking with the key is not working properly. Locking the car with the key does not lock the back doors (left nor right) but locks the front and boot ok. Pressing the lock button inside the car locks everything ok.
    Where should I look next? How do I find the mystery wire problem?
    Thanks in advance
    Edit: its a 2005 mk5 1.9tdi golf
    Mar 2013
    Brisbane QLD
    dont worry about the single wire mode fault it makes no difference to the operation.. the convienence CAN can work on only one . it has 2 wires so it has a back up but as its not a saftey system ie airbag etc it will continue to work ok... is there no faults for any of the door locks?. i would get one new remote.. code it up and test from there...VDUB...
    VOLKSWAGEN TECHNICIAN - 16 YEARS OF PAIN..
    VCDS CODING- FAULT DIAGNOSIS - PRE PURCHASE INSPECTIONS- REPAIRS
    9W2 BT KITS -$300 - 9W7 BT KITS - $450 - CANBUS UPGRADE $150
    BRISBANE / GOLD COAST
    May 2012
    Quote Originally Posted by vdubmotorworx View Post
    No faults on the door locks - but I only have a cheap scanner, do they sometimes miss things?
    And neither of the rear doors work - meaning unlikely to be a fault in the door but somewhere further up in the system I would think?
    Mar 2013
    Brisbane QLD
    yeh some scanners so miss stuff. doors locks are common on golf 5. but usually the doors are locked and cant be opened when they fault..
    Mar 2013
    Brisbane QLD
    i would still get a remote working first then see if you have a rear door fault after that. start with that... get the car unlocking via a remote and then recheck whats happening....VDUB...
    Dec 2009
    Kew, VIC
    That one remote failed before the other suggests that the batteries may be low, so my first move would be to change one — they're cheap (CR2023, from memory) readily available on the 'net and from computer shops and not difficult to DIY.
    The locking fault could be due to a faulty wire where the cables pass from pillar to door usually the driver's door, which gets the most use.)
    It's a well-documented problem, as also are failing MkV door locks.
    May 2012
    Quote Originally Posted by Idle View Post
    Yes - tried changing the batteries when they were failing without success.
    Had a look at the wires in the drivers door (as much as I could see without taking the door card off) - and they looked ok. Would this report as a fault in VAG-COM?
    Dec 2009
    Kew, VIC
    Quote Originally Posted by maelgwn View Post
    It should, but might not — any break ought to be where the wires actually flex, and may not be obvious.
    Look for signs of unevenness or heat marks in the insulation — if you find any, tug at that point and see if it will stretch a bit.
    If it does, the wire is likely to be broken (note that the broken ends will make intermittent contact until the ends burn away a bit.)
    May 2012
    Which module talks to the remotes? Is that the CCM or something else?
    Dec 2008
    NSW Sydney
    If you have problems with driver door lock, check wires in black rubber grommet between the door and chassis.
    2005 Golf V 2.0TDi DSG U/Grey S/roof - SOLD
