Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: Central Locking woes
    Mar 2013
    Brisbane QLD
    46 convienence unit still on a mk5 .. newer ones are through 09 central electrics...
    VOLKSWAGEN TECHNICIAN - 16 YEARS OF PAIN..
    VCDS CODING- FAULT DIAGNOSIS - PRE PURCHASE INSPECTIONS- REPAIRS
    9W2 BT KITS -$300 - 9W7 BT KITS - $450 - CANBUS UPGRADE $150
    BRISBANE / GOLD COAST
    Mar 2013
    Brisbane QLD
    start with one thing at a time.... remotes.. forget the back doors for now.. did the battery have 3 volts? when the battery is in the remote does the red light light up on the remote? if yes to both and you have VAGCOM try and recode the remote as sometimes they can loose there code when its had a flat battery...VDUB...
    May 2012
    Quote Originally Posted by vdubmotorworx View Post
    Ok - thanks VDUB. Ill check battery voltage tonight but red light comes on.
    Dont have VAGCOM but will ask Transporter to try programming the keys next time he is around.
    Mar 2013
    Brisbane QLD
    I actually had one that the battery had 3 volts but it still didn't work, didn't have a remote in stock so just by the off chance I fitted a new battery and all was ok, might be worth getting one anyway as they are only about 4 bucks. CR2025 I think.. it will say on the battery....
    May 2012
    Well - I finally looked into this some more.
    The automotive locksmith said that the remote seemed to work ok (generate a signal and be readable by the car) but he couldn't program it. Tried a new remote and it worked ok, so now I have a new remote.
    However it still doesn't lock the back doors.
    So, symptoms now are:
    Front doors and boot now unlock and lock fine with the remote, key in the door and drivers button.
    Back doors unlock fine with the remote, key in the door and drivers button however they DO NOT lock with the remote or the key in the door. They do lock with the drivers button.
    When tested through the comfort module, front doors and boot lock ok, however the test stops at the back left door - no response from the lock actuator on this door. Because the test stops it does not try to lock the right side back door.
    Does anyone know any differences in how the drivers button works compared to the remote locking? Does the drivers button send a different signal than the Comfort Control Module when locking the car?
    Hi Maelgwn,
    I have had time to have a quick look into it. The fault code was coming up in the central electrics control module as well as the back door modules. It was odd that the remotes would unlock the doors but not lock them and the Lock/ Unlock on the drivers door would work them fine.
    The fault code looks like it could be related from anything that talks on the CAN network as well as a damaged wire, as you know that the doors work I think it would unlikely be a wire. I'm leaning more towards the Central electrics module.
    I haven't pulled one apart (Yet) so I'm not 100% sure on how it works but I'm thinking that the rear doors would work as one output, I think that it would be this which is not working. It could be from either a damaged component on the PCB, corrosion or dry solders, I have found the dry solders to be common in VAG cars so this is where I would be starting.
    One way that you can try narrow this down is to unplug the CECM from the CAN and see if the fault goes away.
    May 2012
    Quote Originally Posted by AALocksmiths View Post
    Thanks
    I'm assuming you mean the Comfort Control Module?
    I pulled it out and pulled it apart a while ago and there was not anything obviously wrong with it. I'm not the most experienced with this stuff but it looked fine.
    When the CCM was disconnected nothing further was revealed by scanning - from memory the error was then something like Comfort Canbus Open Circuit, instead of single wire mode.
    No, not the comfort module.
    The CECM from what I have read should be above the peddles and has a couple of relays sticking into it.
    I have been looking into what functions can be changed in each module and both the Comfort and the CECM have options for the door locks, so this might be why the back doors lock from the switch on the drivers door but not the remote.
    I don't think that with your car the modules are coded to the car so you might be able to get both computers from a wreck and swap them over to see if that fixes it, they will most likely need to have the functions coded but that's not an issue. The other option is to remove both modules and check all the solders and connections. If you wanted I can help you out with that.
    I will keep looking into it though to see which parts each module play with the locking and unlocking of the doors as that will help narrow it down.
    May 2012
    Ok - pulled the CECM module. Didn't reveal anything and all connections look fine.
    Had a breakthrough though. Noticed that when you lock the car with the key you can't open the door from the inside, however when you lock from the drivers button you can still get out. Also when you unlock the car - if you only open the back left door the car still locks itself after 30s like no one has got in.
    So this lead me to the wiring harness in the back left door - it's wrecked! Noticed at least 4 completely broken wires back there ...
    Happy to finally find the problem
    May 2012
    Does anyone know a reliable alternative source of the upgraded wiring harnesses?
    Its $200 and 2 weeks from VW! All the ones on ebay look like the old style/not upgraded with more reinforcement and length around the bend.
