Originally Posted by
AALocksmiths
I haven't pulled one apart (Yet) so I'm not 100% sure on how it works but I'm thinking that the rear doors would work as one output, I think that it would be this which is not working. It could be from either a damaged component on the PCB, corrosion or dry solders, I have found the dry solders to be common in VAG cars so this is where I would be starting.
One way that you can try narrow this down is to unplug the CECM from the CAN and see if the fault goes away.
