Hey guys,
Had this happen to me on the weekend too whilst on my way back from the SA cruise (yes, I bailed part way through!) - got some mis-fires while pulling up-hill hard around 4k RPM.
Checked with my scanner and had P0300 & 0301 codes recorded.
Seemed to be running ok later that day with no issues, and same yesterday, but did have abit of a moment at low RPM (like 1800) on my way to work today (just a little bit of throttle when in 6th at around 60kph).
Car is at 100k km, and I don't think it has had a de-carbon done in any previous service (need to double check), and plugs were probably done 5-7 years ago also.
So - would you recommend that I first try a de-carbon process with something like the liqui-moly product?
Then do Plugs if still no joy?
Then do Coil packs if still no joy?
I think I also need to do my DV upgrade at some point soon (probably go a GFB DV+ kit, currently a RevC stock DV). Thought it was that when it happened actually (until I got the code details).
Is doing a carbon clean process just going to make it worse if it is the plugs or coils? Could I end up not being able to start the car at all?
Is there anything else to watch out for using these de-carbon spray packs at home?
Thanks!
Current - 2007 Golf GTI, DSG, RCD510, K&N Panel Filter, BSH PCV revamp, Bluefin Stage 1 tune, 18" Omanyt's with RE003s.
Previous - 2003 Renault Clio Sport 172 - Flame Red. -Gone-
