IT went well thanks Locky!
I had to replace one of the bolts on the dogbone as they supply a spacer and a short bolt. Did not look so safe to me as there was not many threads securing it to the subframe so i got a hold of a longer one for piece of mind.
I gave it a bit of the old launch control on the way home to find zero wheel hop... job done and very pleased with it so far. I can notice a very slight vibration but nothing to worry about compared to what other people have
The exhaust got welded up nicely. There was a bit of gap to fill but it looks pretty good in my opinion.
I had planned on deleting the Vband joints but they lined up properly and sealed perfectly even with the cheapo Chinese clamp.
Cold start is loud as hell as well as when it gets on boost and dumps out the wastegate but it is otherwise as loud as it was before under "normal" driving conditions. Some extra pops and burbles on over run and some really crisp DSG farts now which was a nice bonus
I did not use a C02 sensor spacer as i was in a hurry to get it finished but there is no CEL to speak of as yet after 200km. I'll report back if it ever appears.
The boost gauge also got fitted. I was a bit surprised to find it reads as high as 22-23psi in the lower rev range before rolling back to around 14-16psi in the higher rev range. That explains why it pulls so well lol.
I'm hoping the CPU does some re calibrating over the next few days but i have noticed it comes on boost a lot sooner and a lot stronger obviously from being able to breath now.
Intercooler next and most likely find a new tune for it.
