whole cluster as far as I know and then it will need to be coded to the car as the immobilizer is in the dash cluster. common for them to fade out or turn back when its hot inside the car
Hi guys my dash cluster screen is starting to fade at the very bottom and I'm wanting to know are they replaceable or does the whole cluster have to be replaced?
VOLKSWAGEN TECHNICIAN - 16 YEARS OF PAIN..VCDS CODING- FAULT DIAGNOSIS - PRE PURCHASE INSPECTIONS- REPAIRS9W2 BT KITS -$300 - 9W7 BT KITS - $450 - CANBUS UPGRADE $150BRISBANE / GOLD COAST
I believe that going the dealer option will cost you around the $2,000 mark for a new cluster and coding of your existing keys.
What car do you have and do you know the part number of your cluster, it's on a sticker on the bottom of the cluster.
I have the same problem.
Would it be possible just the buy a replacement screen? Then pull apart the cluster and solder the new screen in place of the old one?
If the issue is just the screen then there shouldn't be any issue with fitting a replacement. I am not sure how the screen is mounted in these as I haven't had to pull one apart yet but as you said it will most likely need to be soldered in..
