Results 1 to 8 of 8
Thread: Bulb Out warning light -Brake
    Jun 2008
    Wollongong, Oz
    Perhaps someone can help? I have an intermittent "bulb out" warning light occasionally displaying. It relates to the near side brake light. I have checked the bulb and it is OK. Even so, I replaced it, and checked it was working fine. The issue is therefore not the bulb, but perhaps a connection somewhere?
    When the warning light is displayed, the brake light bulb does not work. However, the light will eventually start working again, and the warning light extinguishes.
    It is an intermittent thing.
    The bulb socket is good and tight fitting.
    Any ideas?
    MY22 Tiguan 162 Elegance
    Sound and Vision , Sunroof packages
    Fireball Graphene Butterfly ceramic coating
    Thinkware U1000 dash cams
    Dec 2008
    Sydney/Canberra
    Check the terminals for the bulb socket, and ensure you're using the correct wattage bulb.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Jun 2008
    Wollongong, Oz
    Terminals are good. and 21w bulb is correct
    Erskineville, NSW
    bulb is probably on the way out.
    I had bulb warnings for 3 months before the bulb went west.
    Melbourne, Vic
    Quote Originally Posted by allypally View Post
    Any ideas?
    Did you replace bulb anyway and leave replacement in?
    If the filament on the bulb breaks, it will stop the bulb working and give the warning, but if just broken, then a jiggle can touch the filament back together again and visually looks fine, until it separates again. I just had this issue on an A3 with the reverse light. Swapped out (put LED's in) and issue fixed.
    Change the bulb out permanently to a new one.
    On my A4, I went through a brake light every 6 months or so. Different sides, and no I was not trailing the brakes. (discs lasted about 180,000km)
    2001 - A4 B6 1.8T Sedan Manual - (sold @ 254,000km)
    2008 - A3 8P 1.9tdi Sportback Manual - (sold 90,000kms)
    2013 - Octavia RS wagon - 1z - Race Blue - TDI - 6M - Leather - MDI - Whispbar S44W - LED interior kit - RVC forward?/retrofit - Mk3 gear shifter
    2021 - Q3 S-Line wagon - F3 - Daytona Grey - Westfalia towbar - no other options available.
    Jun 2008
    Wollongong, Oz
    It is not the bulb. Have replaced it, and swapped it over to the good side. Still an issue.
    Hey love to help. Check if any water has entered the glode holder. It will probly be the holder itself. Give it a go.
    Aug 2008
    South Australia
    I had this same problem for just on 12 months, every second day the warning light comes on and the later it goes of. Checked the globe numerous times, finally it went and I changed bulb all was good till 2 months later the other one went. Then a week later one headlight went, so fixed that and 2 days later the other went. Now all is good again.
