Hi all,
Could use some help to troubleshoot what's preventing my boot from unlocking/opening.
I removed the boot plastic cover and after having a look at the system:
- VW logo doubles doubles down as a switch. When I push the VW logo, the white bite rotates and activates the switch. I can hear a "click" when I push the logo down
- Then the switch mush send a signal to the boot lock latch pictured below for the latch to disengage.
What would be the best way to proceed to figure out which part is the culprit here?
Any help/insight would be appreciated
Just a note, I purchased a mk5 and the fix applied from a very mechanically minded previous owner was to leave the trim off and tied a cord around the latch so you have to drop the back seat, lean in and pull it. It obviously had him stumped too, although mine is intermittent.
