Check out carsystems.pl for all the different types and what works. They also do part numbers.
If you want it to be decent, you'll want an RNS510 regardless.
Hi, got an mk5 r32 2006 with the half height mfd. I'm thinking of upgrading to RNS510 but read that the 9W7 bluetooth kit only works with the full height mfd. What's another bt kit that will work with rns510?
Thanks.
I would like to draw your attention to this post on this forum....
Graphite Blue TDI| DSG | Leather | Bi-Xenons | Custom LED inner tails | Black Forest TAI | OSIR Pod & New South Boost Gauge | Bluefin | Projector Fogs | RNS510 | Skoda Bluetooth | Eibach Pro kit Springs| Full LED interior|US GLI paddle shift MFSW|Carbon Vinyl wrapped trims|Colour Coded Votex Body Kit|
Yep RNS and 9w7 works well with my '05, best decision I've made.
RNS will work with 9W7 but as you have half height display will not show on dash only on radio.....but radio display is good anyway! Plus you will need a new gateway to run a RNS on a 06 golf. "Fartherless one" in the above post might be able to sell you a gateway you need and BT kit can be got from Vincent on ebay from lone cove.....user name. VW_PARTS_AUS. Just give me a shout when you have a RNS, Gateway and BT kit. I can code it and install if you want and also supply a fakra adapter aerial cable you will need to fit the RNS.........VDUB....
Yep, VDUB did my install, perfect![]()
oh...thanks......as I said this man can get you a gateway for your 06 Golf.
VOLKSWAGEN TECHNICIAN - 16 YEARS OF PAIN..VCDS CODING- FAULT DIAGNOSIS - PRE PURCHASE INSPECTIONS- REPAIRS9W2 BT KITS -$300 - 9W7 BT KITS - $450 - CANBUS UPGRADE $150BRISBANE / GOLD COAST
