Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: Battery standby current
    Dec 2008
    NSW Sydney
    Has anybody measured the current that is consumed by the car from battery when it's locked and bonnet is open? I just got a new battery drained over weekend and then with the old one I measured standby current after 1h when all modules suppose to go to sleep mode. It was 0.77 A which I think is 10 times higher than normal rate. Someone was saying in mkV forums that it should be under 70mA.
    I checked - no leakage in alternator, when engine is on - battery negative to chassis is 0V, no AC across the battery - diodes are OK, battery charge voltage: 13.8-14.5V.
    I guess the next step is pulling fuses one by one..
    2005 Golf V 2.0TDi DSG U/Grey S/roof - SOLD
    Dec 2008
    NSW Sydney
    I found the procedure Tech Tip: Volkswagen Diagnosis for Excessive Static Current Draw need to wait for 2 hours!
    Adelaide hills, SA
    Important thing is to close the bonnet as the article says. Otherwise here is the link for similar in our forum. http://www.vwwatercooled.org.au/f136...tml#post393486
    0.7A current draw is too high on our Golf it is less than 20mA after short time.
    Dec 2008
    NSW Sydney
    Done 2.5 hour test, battery is still supplying current at the same rate 0.7A, checked mV across fuses under the bonnet - 4-5 fuses together combine around 0.3A which make me think that ECU is not going to sleep mode...damn will cost a fortune to replace, though I have to check if alternator or starter motor solenoid connection faulty but the battery gets charged, so unlikely ...have to check fuses inside on the driver side
    Jan 2008
    Quote Originally Posted by HiTorque View Post
    Why does it have to have anything to do with the ECU?
    Find what circuit is drawing the power and go from there. Have you scanned the car with vagcom/VCDS to see if there are any faults? Check everything is coded correctly as well.
    Dec 2008
    NSW Sydney
    I left bonnet opened, now I see, but how on earth can I get current clamp output to the meter? I have Fluke...dammit!
    Guest Guest
    0.040amps is prob the best when the CAN-BUS has totally gone to sleep
    Does it have a non genuine radio keeping CAN awake
    Also the Gateway has the ability to keep the CAN-BUS awake
    Door control modules can keep it awake too
    Are you doing test with bonnet latch closed/all doors shut and locked?
    Jan 2008
    I'd get one (or more) of the plug in fuse replacements that have a remote lcd, plug them in to a few locations and position the lcd's so they're visible and lock the car up. Jaycar sell them IIRC.
    Dec 2008
    NSW Sydney
    Quote Originally Posted by VWweirdo View Post
    I did the test with opened bonnet as I didn't know it has a status sensor (?), but all doors and trunk closed, locked with remote, 12V power sockets empty.
    The fuse test under the bonnet after 2.5h wasn't conclusive, but found F24 (10A - Data Bus on Board Diagnostic Module) - 160mA, F31 (30A-Windshild wiper motor) 60mA, F16 (15A -Steering Column Control Module) - 90mA, F3 (20A - Comfort System Central Control Module) up to 90mA. This is why I thought it's still awake. My fuse location map is not quite correct though, I found revision from Oct 2005, my car manufactured before March 2005. Has anybody got a link to fuse maps for all models? VW Golf manual doesn't have references to all fuses. I don't have any electrical mods, non-standard accessories etc
    Dec 2008
    NSW Sydney
    I did more testing with brand new battery (12.77V) and closed bonnet. It looks like car wasn't in sleep mode as battery voltage dropped overnight to 12.55V. I wonder if any particular module is responsible for "sleep" activation or any electrically monitored switches are not working like bonnet or trunk. I don't have VAGCOM but three multimeters and Fluke clamping current probe with a lead to meter
