Hi - I feel your pain, I need to do the same for my GTI.
I’m starting with a voltage drop test on each fuse to isolate which circuit is causing the issue.
(I too have an aftermarket stereo but I’ve had the car w stereo for 5yrs and the drainage issue is new).
There are tables around to identify a) which circuit is which and b) how much voltage drop on a fuse of x resistance = current draw.
Power Probe
How to Do a Parasitic Battery Drain Test | AxleAddict
Oh and I had the battery replaced recently and then my mechanic have a look at service. The best I seem to get out of mechanics is an alternator and battery test - ie. I think parasitic drain takes a bit of work to figure out.
Long story short - I think there’s a lot of guessing when it comes to parasitic drain and checking the voltage drop across the fuses sounds like the best way to get answers, or find an auto electrician.
I’ll let you know how I go, & anyone with direct experience please chime in.
