Sorry, my reply was posted twice.
The table does not match my model, except for the first four connections to the Fan Control Module. Additionally, I could not locate the corresponding fuses in my diagram. However, the fact that the ECU triggers the fans via T4x/3, and that the high-pressure sensor sends a signal to the fan control module, provides useful clues for proceeding with troubleshooting.
Thanks, Mig, for your cooperation.
I am unsure how to test the high-pressure sensor, so I will look it up online.
I connected a large fan that I purchased along with the module from the junkyard, and it behaves the same way as the existing module did. I believe that the fan module is functioning properly and is not faulty.
Unfortunately, the table does not match my model, except for the first four connections to the Fan Control Module. Additionally, I could not locate the corresponding fuses in my diagram. However, the fact that the ECU triggers the fans via T4x/3, and that the high-pressure sensor sends a signal to the fan control module, provides useful clues for proceeding with troubleshooting.
Hi sunda,
I'm interested to know if you were you able to solve the problem in the end. I'm having similar issues.
Thanks
