Results 1 to 10 of 14
Thread: Aircon not working Golf FSI 2L 2005
    Mornington Peninsula, VIC
    Sorry I missed that part, check out this post about the J293 module mk4 Fan Control Module (J293) chart and A/C tips | Ross-Tech Forums
    It has a nice checklist of things to go over, the mk5 will be close still
    The difference with the Mk5 is that the J293 is controlled digitally via the ECM on that pin T4x/3
    Do you have a scan tool that can do output test?
    MY12 Passat FSI Highline | 3.6L VR6 | Cashmere Brown | Driver Assistance Package | Dynaudio | Discover Media | TPMS Direct | Side Assist | Adaptive Cruise | 3D colour cluster | More coming soon
    Genuine VCDS HEX-NET and VCP Pro
    Nov 2024
    Dandenong Vic Australia
    The table does not match my model, except for the first four connections to the Fan Control Module. Additionally, I could not locate the corresponding fuses in my diagram. However, the fact that the ECU triggers the fans via T4x/3, and that the high-pressure sensor sends a signal to the fan control module, provides useful clues for proceeding with troubleshooting.
    Thanks, Mig, for your cooperation.
    I am unsure how to test the high-pressure sensor, so I will look it up online.
    I connected a large fan that I purchased along with the module from the junkyard, and it behaves the same way as the existing module did. I believe that the fan module is functioning properly and is not faulty.
    Nov 2024
    Sorry, my reply was posted twice.
    Nov 2024
    Unfortunately, the table does not match my model, except for the first four connections to the Fan Control Module. Additionally, I could not locate the corresponding fuses in my diagram. However, the fact that the ECU triggers the fans via T4x/3, and that the high-pressure sensor sends a signal to the fan control module, provides useful clues for proceeding with troubleshooting.
