Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Aircon not working Golf FSI 2L 2005
    Nov 2024
    Dandenong Vic Australia
    The table does not match my model, except for the first four connections to the Fan Control Module. Additionally, I could not locate the corresponding fuses in my diagram. However, the fact that the ECU triggers the fans via T4x/3, and that the high-pressure sensor sends a signal to the fan control module, provides useful clues for proceeding with troubleshooting.
    Thanks, Mig, for your cooperation.
    I am unsure how to test the high-pressure sensor, so I will look it up online.
    I connected a large fan that I purchased along with the module from the junkyard, and it behaves the same way as the existing module did. I believe that the fan module is functioning properly and is not faulty.
    Nov 2024
    Sorry, my reply was posted twice.
    Nov 2024
    Unfortunately, the table does not match my model, except for the first four connections to the Fan Control Module. Additionally, I could not locate the corresponding fuses in my diagram. However, the fact that the ECU triggers the fans via T4x/3, and that the high-pressure sensor sends a signal to the fan control module, provides useful clues for proceeding with troubleshooting.
    Mar 2025
    Aldinga SA
    Hi sunda,
    I'm interested to know if you were you able to solve the problem in the end. I'm having similar issues.
    Thanks
