Climatronic?
Is it quiet, as in you can only just hear it?
If so, it's the blend flap adjusting to maintain your chosen temperature.
Hey all,
Did a bit of research on this, basically there were 2 responses:
Fuel lines flapping against firewall - is an issue that was resolved apparently in a service release?
Recirculation valve of some sort in the AC/Heater system behind glove box area.
So I switched off the AC/heater and there was no noise, back on and its usually consistent to idling at the lights and not rhythmic, so different every time. Assume culprit is the Ac/heater unit with flappy valve issue or something along those lines. Flap flap, click click click pause........ flap click.
Anyone got any info on this and if I should just ignore it?
Cheers,
Cheddo.
2006 MKV GTI - Silver / 6spd / APR S1 / Sunroof / 7" LCD GPS Android JB 4.1 Head Unit
Climatronic?
'07 Transporter 1.9 TDI
'01 Beetle 2.0
Yeah quite noticeable when sitting at lights on idle, don't usually have much MP3/radio volume when wife and mini me is with me, this is when I notice the most.
Could be worth trying a basic set on it.
'01 Beetle 2.0
I get the same noise. It is quite annoying, but can't think of what I am doing to make the sound
Although it sounds it goes off at random intervals, I'm sure there is some commonality to ot
What Umai said. I notice the flaps in nearly every climatronic car.
The knocking is the motor reaching its end stop
A basic set may or may not fix it
Sorry, asked this before also - what is a basic set?
Bascially, through a combination of button-pressing, you can run it through a re-learn procedure that will re-calculate all the end-positions of the flap motors.
How to reset and calibrate HVAC flaps in VW Climatronic (Golf, Passat, Jetta, Scirocco, Touran) - YouTube
https://www.youtube.com/watch?v=h9lqvjg8wOY
'01 Beetle 2.0
