Results 1 to 3 of 3
Thread: Advice after leakdown test 2.0 TDI bkd engine
    Nov 2017
    Victoria, Australia
    hello!
    i have had a bit of a saga with my mkV TDI.
    firstly i got it, it blew a little smoke on full throttle, i didnt really care too much. kept it serviced, topped up with oil and ran fine still getting great fuel economy.
    then it started runnign a bit rough at around the 250k kms mark, so i got a timing belt put in.
    a few weeks later, she wouldnt start.
    replaced EGR
    replaced Crank and sensor,
    and put a new battery in it.
    after i put the crank angle sensor in, she started and ran a few times, but the CEL came on, and my code reader isnt great so i took it back to the mechanic.
    the mechanic did a leakdown test, and diagnosed cylinders 2 and 3 as having screwed exhaust valves. Which is evident by the back pressure which is now audible in the air intake box.
    According to the mechanic next step is to drop a new engine in there.
    i am pretty broke, and have just put the money into the timing belt, EGR, crank sensor, battery and a set of ok second hand tyres on it.
    my questions are,
    am i getting taken for a ride by the mechanic?
    is there anyone who can do a top end rebuild (reseat and replace valves) in Melbourne?
    is an engine replacement a reasonable option?
    256k kms. otherwise perfect car.
    thanks!
    Adelaide hills, SA
    Did the same mechanic tell you to replace all these parts that you did?
    Nov 2017
    Victoria, Australia
    the mechanic suggested i replace the timing belt and the crankshaft position sensor.
    the battery, tyres and EGR I did myself.
