Results 1 to 10 of 11
Thread: AC Condenser Fan on MK5 Golf
    Jul 2011
    Perth
    Hi Guys,
    I have had to take off my Radiator housing off the front of my MK5 and once reinstalled, as soon as I had battery connected the AC condenser fan ( smaller one ) comes on without even starting the car.\
    Has anyone had this problem before? Any suggestions.....what should I be looking at?
    Thanks in advance.
    Al
    Feb 2013
    east kurrajong, new south wales
    Have you reconnected the ambient temperature sender?
    Jul 2011
    Perth
    Not sure what that is? ambient temperature sender
    Please elaborate?
    cheers
    Jul 2011
    Perth
    Is this the sensor under the front bumper? Outside temp sensor?
    Feb 2013
    Quote Originally Posted by ak77 View Post
    Yes usually clipped on the front bumper cover at the passenger side of the centre lower grille.
    If this is unplugged or faulty it will cause the fans to operate at 100%
    Mar 2013
    Brisbane QLD
    If its not plugged in you wont have your air temp reading on dash display....
    VOLKSWAGEN TECHNICIAN - 16 YEARS OF PAIN..
    VCDS CODING- FAULT DIAGNOSIS - PRE PURCHASE INSPECTIONS- REPAIRS
    9W2 BT KITS -$300 - 9W7 BT KITS - $450 - CANBUS UPGRADE $150
    BRISBANE / GOLD COAST
    Jul 2011
    Perth
    In that case , yes I did remove it and installed back again ? let me know what you'r thinking
    Jul 2011
    Perth
    Is there a way to see if the sensor is faulty ?
    Dec 2008
    Sydney/Canberra
    Either that, or the fan module has picked the perfect time to cark it.
    It runs the fan at full speed all the time, and drains the battery.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Mar 2013
    Brisbane QLD
    The sensor be faulty if NOT showing a reading on your dash...does it show say 30oc on dash? If it doesnt and shows nothing then you know sensor has a issue or not connected.......
