Have you reconnected the ambient temperature sender?
Hi Guys,
I have had to take off my Radiator housing off the front of my MK5 and once reinstalled, as soon as I had battery connected the AC condenser fan ( smaller one ) comes on without even starting the car.\
Has anyone had this problem before? Any suggestions.....what should I be looking at?
Thanks in advance.
Al
Not sure what that is? ambient temperature sender
Please elaborate?
cheers
Is this the sensor under the front bumper? Outside temp sensor?
If its not plugged in you wont have your air temp reading on dash display....
VOLKSWAGEN TECHNICIAN - 16 YEARS OF PAIN..VCDS CODING- FAULT DIAGNOSIS - PRE PURCHASE INSPECTIONS- REPAIRS9W2 BT KITS -$300 - 9W7 BT KITS - $450 - CANBUS UPGRADE $150BRISBANE / GOLD COAST
In that case , yes I did remove it and installed back again ? let me know what you'r thinking
Is there a way to see if the sensor is faulty ?
Either that, or the fan module has picked the perfect time to cark it.
It runs the fan at full speed all the time, and drains the battery.
'07 Transporter 1.9 TDI
'01 Beetle 2.0
