Page 1 of 3 123 LastLast
Results 1 to 10 of 27
Thread: 9L/100Km is this normal for Auto 1.6L Petrol?
    Hi everyone,
    I've had my 2005 Mk5 for about a month now. Avg fuel consumption is 9L/100Km. Is this about normal for Auto 1.6L Petrol? I drive normally (hardly revving the car at all), combination of freeway + stop and go. I use regular unleaded.
    Related question:
    - would changing to higher octane fuel make a difference?
    - would fuel additives make a difference?
    - what about one of them resistor mod they sell on eBay?
    Thanks a lot in advance.
    Aug 2007
    Perth, Australia
    Quote Originally Posted by drotsap View Post
    IMO BPs ultimate 98 is the best fuel. I use it on my car and consumption is less than if i put 91. I tried it once
    Additives are for older cars and i'd never use them on a car like yours
    resistors off ebay are a joke IMO
    1991 BMW 318is RED E30
    Apr 2008
    Check your tyre pressures...... when one of my tyres were going flat the fuel consumption went up by about 1-1.5L /100
    Adelaide hills, SA
    Driver will effect fuel economy easily by 30%.
    I would ask you what did you drive before and what fuel economy figures you were getting? How long are your trips, how many people and how much luggage is in the car?
    otherwise 9l/100km from 1.6 auto engine in mixed driving condition is not that bad.
    Try different petrolstation and different brand of fuel.
    I wouldn't modify the engine managment your car is optimaly tuned from the factory.
    Just a couple of things that affect the fuel economy:
    Use of air conditioner
    Tyre pressure
    Outside temperature
    Driving up the hill
    Jun 2008
    South Coast N.S.W.
    Just a couple of things that affect the fuel economy in your new car:
    Tyre pressure
    Outside temperature
    Driving up the hill
    And don't forget
    Too much lead in right foot
    Seriously though, a lot will depend on how many k's it has travelled and the servicing history as well. Drive.com.au has the fuel specs for city driving at around 8.2 L / 100 km so depending on other things which have been mentioned already (tyre pressures, driving style, type of fuel used ...etc) and the conditions that you're driving in as well (ie hot, cold, windy...) all these things can and will have an affect on fuel consumption. Considering it is only a relatively small engine with 75kw power outlet and the size and weight of the Golf itself, IMO the fuel figure of 9L / 100km is probably not too bad.
    Russ
    Russ
    2005 Subaru Outback 3.0 R Premium
    Camden, Sydney
    Use 98 Octane Petrol as specified by the manufacturer.
    Jan 2008
    Sunshine Coast
    Resistors off e-bay CAN indeed make a difference, but it's a rough "overall" effect. In an ex's PT cruiser, a simple e-bay resistor made it a whole lot peppier to drive, but at the expense of economy. For once I'd agree with the others and avoid such "rough" fixes.
    The best thing you can do is experiment with driving styles, ensure you aren't carrying around a ton of stuff you don't need to, and try to avoid heavy acceleration, coast up to the lights etc, adopt more relaxed driving styles. Tyre pressures is a good tip Tom!
    Probably wouldn't hurt to run a bottle of injector cleaner through it, as dirty injectors etc will cause the car to use more fuel than it should. When was the air cleaner last replaced, as it's a simple and inexpensive job, and if it's a bit blocked will waste a lot of fuel as well.
    Jul 2005
    I would be dissappointed with 9L/100km, but then again, I certainly wouldn't be using 91 RON. I'd be sure that the minimum requirement by VW would be 95 RON (Preminum).
    Try a few tankfulls of 95 RON and see if you get better economy. Repeat with 98 RON (Recommended by most here) and compare the results.
    As for fuel additives, 98 RON will do more than fuel additives, and cheaper.
    Maris
    Erskineville, NSW
    As the others have stated - what is the minimum fuel requirement as stated on the decal inside the fuel filler flap - i thought all the non-turbo engines were 98ron.
    Also - the 1.6 is a true auto isn't it? (not DSG), so possibly somewhat inefficient.
    Tyre pressures? I'm thinking 34F/32R would be a good place to start.
    Air con? The AC uses an extra 1L/100km on my car.
    Traffic conditions? On the highway i get <6.5L/100. Driving into the city in peak hour it's more like 10L/100km. Also you don't say where you live. Sydney-siders usually get worse economy due to the high traffic density & crap road systems.
    The 1.6 Auto can be an economical car when if driven correctly. I achieved 4.4L/100km a few years back in a MkV 1.6 Auto using Shell 91ron as part of the Shell Fuel Economy Trial. It was a mixture of suburban & country driving but only about 250km distance and we drove all the other road users insane.
    Jul 2005
    PS; A Mk IV Manual of friend Keiths was down to 6L/100. Given the difference in cars/transmission, it's still a big difference.
    Maris
