I was wondering if anyone would notice.
The pipe from crank case to rocker cover had totally disintegrated and the poly pipe was a nice fit - just needed to heat it up a little to stretch over the fittings, The PCV valve diaphragm had torn some time ago so to prevent excess crank vacuum I plug the manifold port and rerouted the rocker cover outlet to the air filter box. I wanted to go in between the air filter and the throttle body but that was no nice place to tap in. I havent measured the vacuum there yet but its better than nothing and wont be sufficient to cause damage to the seals.
The poly pipe goes a bit soft when it heats up but there is no significant vacuum or pressure on it to cause any problems. Its easy enough to go back to the correct configuration when i get my hands on the right parts. Being a BLX motor nothing seems to be readily available for it.
