Page 4 of 19 FirstFirst ... 2345614 ... LastLast
Results 31 to 40 of 187
Thread: 2.0 FSI Poor idle when cold
  1. #31
    Mar 2009
    Goulburn NSW
    Quote Originally Posted by MEL744 View Post
    Are there any values that would be helpful to log? Or just all of them like you mentioned?
    Im using the scatter gun approach - I do a scan off all the blocks and then try and find some that I think MIGHT effect the cold start... I had been conecntarting on manifold pressure/temperature/egr/injector timing.
    i wish it was possible to log everything while starting rather than been limited to about a dozen values.
    Its pretty easy to check the gears in the egr you can pull the cover off with the egr valve still in the car, its only about 6 screws.
    its also reasonable easy to remove the whole valve as well if you want to clean it out.
    have you done a full vcds auto scan ??
    if your engine usues the more common purge valve i have a good (new ) that doesnt fit my daughters car i ordered incorectly..
  2. #32
    May 2016
    Melbourne, Victoria
    Fair enough, I will try to log some more values over the next few days, fortunately I can use Matlab to quickly plot everything, maybe then something will jump out. Haven't done a full auto scan, just scanned the engine. Also today while changing the oil I noticed something interesting. When I started the car to move it into the driveway it did its usual high idle. Then about an hour or so later it did it again when it was time to go into the garage. This seems to suggest that there is another factor at play than simply the time (~= 6 hrs) as previously thought.
  3. #33
    May 2016
    Melbourne, Victoria
    Auto scan done - no issues other than door lock fault. I think I will adopt your strategy of testing as many blocks as possible, I'm currently writing up a quick script to automatically process the log files, plot them and export to PDF. Would be happy to process any log files you have too.
  4. #34
    Mar 2009
    Goulburn NSW
    That would be good I can muddle my way through excel but thats about it.
    Thats interesting that the issue showed up after such a short time - I FEEL like its a temperature sensor issue but so far nothing is showing up out of the ordinary.
    Ive been comparing all my blockmap logs taken before starting the car - some will be when the car has run well and others aill be when it runs bad the only problem is I didnt make a note of which ones were good and bad
    a couple of things I ve noticed that seem to be significant - Low manifold vacuum (770mmHg), severely retarded timing (-25deg), high throttle opening at idle (13deg)
  5. #35
    May 2016
    Melbourne, Victoria
    Quote Originally Posted by saabman View Post
    I was doing some research on this recently, and found someone mentioned changing the pre-cat lambda sensor resolved the issue. Based on the age of the mk5 I would guess it has heated lambda sensors - I wonder if there is some strange condition with the high-idle warm up and the heating of the lambda sensors that causes incorrect readings? Keep in mind also found a million other suggestions for it - will have to see what the logs are showing - haven't plotted any yet.
  6. #36
    Dec 2009
    Kew, VIC
    Might be as simple as an injector not fully sealing.
    Cheap piezo injectors in printers are famous for it.
  7. #37
    May 2016
    Melbourne, Victoria
    That seems reasonable, but I have read of other people with the same issue replacing injectors and nothing changes - which is why I am slightly hesitant to change them.
  8. #38
    Mar 2009
    Goulburn NSW
    Yes the pre cat lambda sensor seems feasible. I wonder how we could see that I the data collected. If the ecu can see a problem the logs of data from the sensor should indicate it as well.
    It’s obviously providing a reading that is valid but not correct for the rest of the engine perhaps if it’s say reading rich the ecu would lean out those cylinders this would increase knocking which would retard the timing ???
    I remember seeing some knocking on cylinders 3 & 4 but put it down to the engines running crap of course it’s going to knock I’ll have to have another look at the data.
    I’m expecting to see low injection times for cylinders 3 and 4 and longer times for 1 &2
  9. #39
    Mar 2009
    Goulburn NSW
    Quote Originally Posted by Idle View Post
    An injector not sealing I would expect to show up as a drop in fuel pressure over time - I haven’t seen that yet ...
    I’m using this fault as a good way to learn how to read the data from the car and am planning on not replacing anything unless the data shows a problem. We have amazing tools that give incredible insight into the running of the engine which I can only dream of on my Kombi. The trouble is interpreting the data in a meaningful way
  10. #40
    Mar 2009
    Goulburn NSW
    I started doing a bit of research into this and come accross this page about reading lambda values in conjunction with other gas readings for engine diagnosis https://www.austincc.edu/wkibbe/lambda.htm
