Page 7 of 19 FirstFirst ... 5678917 ... LastLast
Results 61 to 70 of 187
Thread: 2.0 FSI Poor idle when cold
  1. #61
    Mar 2009
    Goulburn NSW
    With the above in mind I just had another look at your sensor voltages and it appears that B1S1 is almost the inverse of the other 3 sensors. When 1 goes +Ve the others go -Ve.
    I am under the impression that the first sensor is used for mixture control
    And the others for checking cat effectiveness. If that is the case and it reports incorrectly rich the ecu will lean things off which seems to be what the othersensors are showing.
    Interesting that the 1st sensors base line is about 1.5v and the others are around .5 v at engine start. I need to check but I seem to recall my first 2sensors at around 1.5v at engine start and the others at about .5v. Is this an issue or a function of the sensors in the manifold v the sensors further down the line?
  2. #62
    May 2016
    Melbourne, Victoria
    Yep my understanding that B1S1 is mixture control and the other 3 are cat effectiveness. The reading of 1.5V seems very strange indeed, and I can't find anything that points to a reading over 1.5V as normal. It would be good to see what the sensor 1s are reading on your engine. If both your sensors are reading 1.5V then I guess it is normal? (time for more research I think) If these were cheaper I'd be willing to take a gamble on buying a new one and seeing how it goes. Was going to consider disconnecting the sensor and taking some readings with a multimeter. However the only thing that could be checked is the operation of the resistance heater since we already have the voltage produced under operation. Could the 1.5V be a short of some sort?
    I had come across one post on a forum where a cracked exhaust manifold was causing the rough start - might also be worth taking the heat shield off and having a look. Agreed it is absolutely fascinating to look at all the differences between what are on the surface very similar engines.
  3. #63
    May 2016
    Melbourne, Victoria
    Found a YouTube video about diagnosing the VW lambda sensors. This guy is getting a voltage of 1.5V on VCDS, which he says is not normal, and proceeds to check the voltage and resistance of the pins on both the ECU and sensor side. Will try this by the end of the week hopefully. This only applies to narrowband sensors, I'm not sure what these engines have - another thing to find out. Also surely the car would throw an error code with implausible signal if the reading was supposed to be between 0 and 1 volts yet it was showing 1.5v...
  4. #64
    Mar 2009
    Goulburn NSW
    Yep everything I have seen on diagnosing o2 sensors says around 0.5V is normal but I noticed in the label file for the ALX engine which is what Im useing as a best guess specifies the pre cat sensors as between 0 -5V and the post cat sensors 0.1 - 0.8V so 1.48 looks like a plausible signal.
    id love to see a log of sensor volatges from a known good engine to compare with
  5. #65
    May 2016
    Melbourne, Victoria
    Readings from a good car would be very helpful. I think that the pre-cat sensor is in fact a wideband one while the post cat are all narrowband. When the mixture is stoichiometric the current will be 0. Some cars report this as voltage, others as a lamda value. I have also heard its possible for wideband sensors to respond faster than narrowband, which could explain the spikes from the sensor. I'm not 100% convinced there's a problem with the sensor, really need some data from a car that is working properly.
  6. #66
    Mar 2009
    Goulburn NSW
    i agree..
    its frustrating that given how popular these cars are how little technical information is available, even an accurate parts list is like unicorn ****
    I used to think the dealer mechanics were dumb arses but if they only have this crap elswin system they dont stand a chance
  7. #67
    Mar 2009
    Goulburn NSW
    I just got elsawin working a bit better, It ddint work real well under win10 so I just created a winXP VM and installed it in that and its a lot more reliable, I can print and make pdfs as well which is really handy.
    The BVY Exhaust sensors are
    G39 - 5 wire Lambda probe in manifold in what appears to be connected to cylinders 1 and 4 Bank1 Probe 1
    G130 - 4 wire Lambda probe after Bank 1 Cat. Bank 1 Probe 2
    G131 - 4 wire Lambda probe after Bank 2 Cat. Bank 2 probe 1
    G287 - 4 wire Lambda probe after second Cat. Bank 1 probe 3
    The BLX exhaust sensors
    G39 - 5 wire Lambda probe in bank 1 manifold for cylinders 1 and 4. Bank 1 Probe 1
    G102 - 5 wire Lambda probe in bank2 manifold for cylinders 2 and 3. Bank 2 Probe 1
    G130 - 4 wire Lambda probe after bank 1 Cat. Bank 1 Probe 2
    G131 - 4 wire Lambda probe after bank 2 Cat. Bank 2 Probe 2
    G235 - Exhaust temp sensor just before NOX storage cat
    G295 - Nox Sensor Just after NOX storage cat
  8. #68
    May 2016
    Melbourne, Victoria
    5 wire will be a wideband, have seen some posts indicating that 1.5V represents stoichiometric A/F for VW o2 sensors. It appears you can run some Lambda aging tests, so might give those a go - other than that not sure what else to do really.
  9. #69
    Mar 2009
    Goulburn NSW
    I had also read about the aging tests but have not been in a position to try it out.
    I think getting to understand the significance of the fuel trim figures will lead us in the right direction. Haveing the 2 sensors in the manifold in the BLX engine will help as I can see a distinct difference between the two pairs of cylinders which to me indicates it is not something like the fuel pump or an intake leak.
    Even though you only have the 1 manifold sensor you do have 2 further down stream all be it with a lower resolution there may still be enough to narrow the location down.
    I’ve been working through a couple of YouTube videos about using fuel trim for diagnosis they are about 1/2hour each. I’m hoping I will learn enough to find the fault with out replacing everything in the engine bay until the fault goes away
    Can I suggest logging all the lambda sensors and all the fuel trim readings for a complete journey.
    A compression test or even better a leak down test would possibly be useful. I’m contemplating swapping cars with my daughter again for a few weeks so I can have another look and get some more data out it.
    We have a couple of 2 liter tfsi caddy’s at work I’m trying to get my hands on one to grab some data out hopefully that will give us an idea of what a good engine looks like. My work caddy is a TDI so I don’t think it would gives us comparably figures.
  10. #70
    Mar 2009
    Goulburn NSW
    Here’s the link to the fuel trim video I’ve been working through.
    YouTube
