The information in the Label files does seem to be a bit vauge and "best guess" with the amount of variations in VW engines Im not surprised no one can really hit it on the head ...
I was watching a youtube video about Fuel trim at lunch time today YouTube
and from what I could gather from that the voltages from the O2 sensor should remain pretty well steady ( should oscillate around 0.45V ) if the they sense a richer mixture the ecu should reduce the injector timing if the sense lean the ecu should increase injector time this would be seen as a variation of the fuel trim values. The ECU should be doing everything it can to keep the O2 sensor values constant. There are times it should vary like when accelerating or decelerating.
