Hi drbluetongue, first of all thank you for joining and replying. Nowadays it is really rare to see someone share his knowledge. People on this forum proved to be an exception
As for high idle after cold startup, i confirmed the ECU switches to different mode (010000001). In my case, engine misfires like hell on 1st cylinder (~80 misfires) and few mis on second cyl but only in warm months. In winter it is clean high idle without misfires, strange ha? After that it stays in homogeneous mode (000000001) during entire drive.
edit: today i started car in 10°C and high idle was without single misfire, mode was 000000001 entire time. So it is definitely temperature dependent.
x?xxxxxx variant is not mentioned in VCDS label but it should be some form of double injection for rapid catalyst heating as you mentioned (maybe homogeneous split? Stratified CAT heating should be ?xxxxxxx).
Switching map in runtime perfectly supports my observation. I suspected either carbon buildup or ECU playing some game with me. Generally worse acceleration (airflow) after warm up but not always. 4 bad accelerations 2 good even from low RPMs and so on. ECU compensating for something making much more sense.
I've already logged couple of hour test drive for knocks and it knocks only during high idle startup. Even idle after warmup is perfect with 0,8l/h (PCV is OK i guess).
Which MVB are you talking about when you mention
- ignition, timing angle [ °BTDC ]
- timing retardation, cylinder 1-4 [ °KW ]
- camshaft adjustment, intake B1 [ °KW ]
- phase position, bank 1 intake
- injection timing [ ms ]
I am very eager to "fool" NOX subsystem but preferably after solving this damned hesitation.
Thanks
