I gave up on the Nox sensor - I did try a second hand unit but that didn’t make any difference so just left it.
Ok when cold but gets bad when hot sounds like something leaking as it warms up. You may not notice it when doing a smoke test as the engine would be cold. I’m not sure how you would test did that though maybe squirting carbybcleaner or Aerostart around the joints in the manifold when it’s hot and seeing if you can detect a change.
I started translating the funktionsrahmen it’s on my GitHub page I’ll grab the link shortly and post it. I just used google translate to do it so it’s a bit rough but gets the idea across. I’ve only done a few chapters but if you have a look through the index and let me know what chapeters look interesting I’ll try and get them done. Or you can have a go and add them to the repository.
The MAP sensor can fill with oil it’s on the lower front passenger side of the intake manifold - a single torx screw from memory holds it in - might be worth haveing a look at that as well. Unfortunately I don’t have ready access to the car my daughter lives about 2 hours away so don’t see her unless the car breaks down
