Results 1 to 7 of 7
Thread: 2.0 FSI P1403 Regulation Deviation
    May 2016
    Melbourne, Victoria
    Hi all,
    For a while now I've been getting the occasional check engine light relating to the EGR system. Up until now I've just been clearing them to see what happens - normally the reappear after a few months so not a big issue. They normally come on while driving, however last week one came on immediately after start. Since cleared and has not come back, but the freeze frame data was a bit strange.
    P1403 - 008 - Regulation Deviation - Intermittent - MIL ON
    Freeze Frame:
    Fault Status: 10101000
    Fault Priority: 0
    Fault Frequency: 71
    Reset counter: 255
    Mileage: 0 km
    Time Indication: 0
    Freeze Frame:
    RPM: 10200 /min
    Load: 100.0 %
    Speed: 255.0 km/h
    Temperature: 215.0°C
    Has anyone had this code for this engine, if so is the only way to fix it replacing the EGR valve?
    Cheers,
    Michael
    According to the Ross Tech info, looks like you are up for either the N18 valve or possibly a new complete EGR valve.
    The N18 is quite a common failure and causes EGR errors, so you might be lucky with just having to replace this.
    17811/P1403/005123 - Ross-Tech Wiki
    Jul 2007
    Brissy
    Have you taken the top off the EGR and looked at the plastic gear in it ?
    Mine was quite worn in one quadrant. I took it out turned 90degrees and put it back in.
    MK4 GTI - Sold
    MK5 Jetta Turbo - Sold
    May 2016
    Melbourne, Victoria
    Checked the gear today, seems fine. Will have to look into it more.
    Mar 2009
    Goulburn NSW
    Freeze Frame:
    RPM: 10200 /min
    Load: 100.0 %
    Speed: 255.0 km/h
    Thats pretty impressive
    Quote Originally Posted by saabman View Post
    Racecar
    Jul 2007
    Brissy
    I got this again today, had it a few months back and reset, it came back today but shows the same mileage, it is currently at 175598km.
    Looking to replace it, or can I fix it somehow ?
    005120 - EGR Valve (N1
    P1400 - 002 - Electrical Malfunction - Intermittent - MIL ON
    Freeze Frame:
    Fault Status: 10100010
    Fault Priority: 0
    Fault Frequency: 20
    Reset counter: 255
    Mileage: 169609 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 08:19:05
    Freeze Frame:
    RPM: 1680 /min
    Load: 19.6 %
    Speed: 40.0 km/h
    Temperature: 45.0°C
    Readiness: 0000 0000
    MK4 GTI - Sold
