Results 1 to 10 of 13
Thread: 2.0 fsi leaking coolant
    Hi guys.
    My 2005 2.0 fsi is leaking coolant. Well now is mainly leaking demineralised water cos the bottle of $31.95 (&#1285451 litre of special VW coollant is now gone
    Ive been replacing it with a mix of coolant/demineralised water for a few weeks now but its just getting silly now.
    The thing is, we (my partner and my 8 month old baby) can’t afford another reaming at a dealer or a mechanic.
    We have spent about 3k on this thing over the past year and a half, and still have the cv joints, a cracked windscreen(not severe but still its another thing thats the best part of a G), and now this to contend with.
    We need this car to keep running as we are not in a positon to buy another just yet...
    So, what Im getting at is, i have noticed a few posts on here where guys have mentioned quoted prices and then another will come on and say “thats a rip i couldve done it for this or speak to me etc” so thats what I’m looking for.
    Anyone that can repair this and knows what they are doing feel free to get in touch.
    I’m in the inner west if Sydney too if that helps.
    Dec 2008
    Sydney/Canberra
    Any idea where you think it might be leaking from? i.e which side of the car?
    Should be a dried-up pink trail somewhere.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Pretty much right at the front/front left. Kinda hard to say because when i see it leaking its always just dripping down the lowest point.
    Dec 2008
    Sydney/Canberra
    Possibly the radiator.
    The locating spigots that secure it at the bottom, are quite vulnerable to knocks, and eventually cause the end-tanks on the radiator to separate from the core. Not a cheap, nor simple job to replace.
    Worth getting it pressure-tested to confirm.
    '01 Beetle 2.0
    You'll have to take the rain tray/cover off from under the engine and take a look up to see where the coolant is leaking from.
    Otherwise take it to a VW specialist (independent) workshop and get them to put it up on a hoist.
    Depends whether you're up for DIY and saving $ or you want to pay someone else to diagnose/fix your problem.
    Nov 2015
    Quote Originally Posted by Davidmangnall View Post
    Hi guys.
    The 1 litre of VW coolant should be a concentrate. There should be instructions on the side of the bottle on the proportion to mix with water to fill the reservoir. I was also told by a old VW fanatic that basically if the mixed coolant has colour and when you rub it between your fingers it is a bit oily (make sure you wash your hands before handling any food or the baby) then it is has enough anti-freeze/anti-boil to work.
    Good luck with finding the leak and repairing it.
    1997 Golf CL, 2011 Caddy Life TDI, 2007 Golf TDI, 1996 Vento GL (red), 2008 Skoda Octavia TDI
    1996 Vento GL (white) - RIP
    Feb 2018
    Do you get Radweld over here? Might be a bodge enough to get you by...
    Dec 2008
    Sydney/Canberra
    Send me a PM, and I'll see what I can do for you.
    '01 Beetle 2.0
    Jul 2010
    Robina Gold Coast
    If your desperate , a short solution might be a Radiator sealant Which might be the best solution ,There are plenty of options out there
    call into Repco or Supercheap ,
