Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: 2.0 fsi leaking coolant
    Dec 2008
    Sydney/Canberra
    I wouldn't recommend them as they tend to block any small diameter coolant hoses the engine may have.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Jul 2007
    Brissy
    Quote Originally Posted by Umai Naa!! View Post
    It could be a few things. Water pump failure - when was it last replaced, should be done with timing belt.
    Also look for split junctions or leaks at hose joins.
    Could even be a head gasket, have you checked the condition of the oil ?
    If you are going to leave it a while then get some red coolant from supercheap auto, I think Nulon make one that is ok for VW, will be a lot cheaper than the dealer, always mix with demineralised water.
    MK4 GTI - Sold
    MK5 Jetta Turbo - Sold
    Sunshine coast
    I had a leak once in my mk5, it turned out to be the reservoir itself that had a crack. Except that time when coolant was leaking into some sensors and corroded the entire engine wiring harness, but that's another story...
    132TSI Tiguan Allspace
