Results 11 to 20 of 21
Thread: 1.9 tdi won't rev, smoke, stalls
    Adelaide hills, SA
    How was it running before it started to misbehave?
    Sent from my iPhone using Tapatalk Pro
    Jul 2020
    Melbourne, VIC
    This is where I'm at...
    Had everything off to do timing, found I couldn't turn the camshaft at all with any sane application of strength. That didn't seem right, so i had the tandem pump off to see if it was binding. That was fine, so I figured I'd pull the rocker cover. Lots of condensation inside... Not sure how or why, although the sump oil looks fine there is milkyness under the oil cap.
    I already had a spare head gasket and bolts here so figured it wasn't much extra work to simply do it and know it's done right (previous owner replaced the head and did a questionable job)
    Took the injector rockers off and the cam spins freely so I guess the injectors just require a lot of torque to get pumping. I'm swapping them out so will see if there's any difference when it goes back together
    Camshaft is like new, as it should be, it IS new
    Running fine, then the turbo blew and the head was replaced due to it slowly using coolant. Put it all back together, now this.
    Adelaide hills, SA
    When you’re at it, before you fit the cyl. head back on, check the TDC of each piston making sure that all are at TDC.
    Mar 2009
    Goulburn NSW
    Just wondering if it appeared after having large number of parts pulled out to replace the turbo and do the head is it possible something as simple as a vacuum line is connected wrong?
    I know I'm guilty of such mishaps
    or parts from the disintegrating turbo lodging where they shouldn't?
    Jul 2020
    Melbourne, VIC
    Do you mean check they all reach the top of the stroke? ie no bent rods?
    Quote Originally Posted by saabman View Post
    Maybe, I'm going to hate myself if I find something like that wrong haha but I have been over all that in detail and can't find anything wrong, although not that I am able to find a vacuum diagram for the BKC golf
    Only the turbo seal failed, nothing broke
    Adelaide hills, SA
    Quote Originally Posted by Tangles553 View Post
    Yes, that’s what I meant.
    Jul 2020
    Melbourne, VIC
    All good, protrusion looks normal
    How difficult should it be to rotate the camshaft with the injectors in? I'm feeling a lot of resistance
    Adelaide hills, SA
    There’s quite a bit of resistance from these unit injectors.
    I had issues with my 1.9 when first running that the map sensor has a busted wire/wire had pulled from the plug.
    made zero power, would struggle to go up any sort of incline or pickup speed.
    Not sure if you have any way of checking its performance?
    Jul 2020
    Melbourne, VIC
    Thanks. Have looked in VCDS and definitely getting what seems to be a normal reading (increases with revs, consistent at idle). The ECU also throws 'implausible reading' when the MAF is connected but the intake piping is not, so it must be fairly sensitive to whether the reading matches what the engine is doing, ie. I don't think the sensor is broken
