I had a similar problem with mine which could relate to your problem.
Go into the secret menu in the climate control and see what it is saying cabin temperature is.
My cabin temp would read lower than it was.
This meant that the climate control wouldn't work properly.
Mine problem was intermittent.
I'd be driving along and say it's 26 deg in the cabin, then the cabin sensor would trip out say it was 19 deg in the cabin
and this would make it blow warmer air out of the ac.
How I fixed mine was put my thumb on the sensor and wiggle it.
When you are in the secret menu and you have the cabin temp showing you can put you thumb on it and watch the temp change.
Sounds weird but it work and I haven't had the problem for over a year.
