Results 1 to 1 of 1
Thread: 06 tdi 6 Speed Transmission Input Shaft Bearing
    Jun 2020
    sydney nsw
    Question 06 tdi 6 Speed Transmission Input Shaft Bearing
    hi I'm having a problem with my transmission,
    This input shaft bearing behind the front passenger wheel, has pretty much exploded and needs replacing.
    06 tdi 6 Speed Transmission Input Shaft Bearing-1-png
    I'm wondering if I buy a kit like this:
    https://www.ebay.com.au/itm/VW-GOLF-V-2-0-TDI-02Q-6-SPEED-LATE-GEARBOX-TOP-BEARING-OIL-SEAL-REPAIR-KIT/173297980650?hash=item28595d54ea:g:UZ0AAOSwf1xcQdp I
    If I can do the job without removing the engine and transmission?
    Also since this bearing has gone, does it indicate I will need to check/change other bearings as well?
    Thanks in advance
    Attached Thumbnails Attached Thumbnails 06 tdi 6 Speed Transmission Input Shaft Bearing-img_2416-jpg
