How many KM's? The OEM suspension could be a bit tired. A good inspection could find some sloppy bushes in need of replacement.
Ensure you get some decent tyres when you renew yours, if it means passing up the wheels then do so. Tyres are probably the best thing you can do for handling.
For brakes, a pad and rotor upgrade will do wonders for stopping efficiency, the OEM setup does not dissipate heat very well.
For rotors, DBA T2 or T3 are a good upgrade.
Pads, you have a huge choice. Check out ECS tuning as a guide, a few of their pads can be sourced in Aus. 403 Forbidden (ECS can be a good place to source all you parts in one go).
A rear sway bar (or both front and rear) from H&R will help curb your understeer issues, along with good tyres. You could also look into some lowering springs from H&R too.
I'm not sure of a place you can get everything done at once but I know Exoticars (Nth Parramatta) can sort the mechanical things for you and right next door is Reflect Effect that can sort the paint.
MY09 MkV BMP 3dr GTI manual
