Page 9 of 12 FirstFirst ... 7891011 ... LastLast
Results 81 to 90 of 117
Thread: When to change a timing belt on Octavia vRS TDi
  1. #81
    Bowral, NSW
    Quote Originally Posted by MountainBikeMike View Post
    What did it cost you? Someone earlier was talking about buying belt kits off ebay for not much
    Quoted $1,580 but got for $1,250 from Camden GTI
    EDIT: Combined with 135,000km service!
    2012 Octavia vRS TDI. Darkside big turbo, 3bar tune, other stuff. 200kW/650Nm.
    1990 Mk1 Cabrio. 1.9 IDI w/ 18PSI.
    1985 Mazda T3500 adventuremobile. 1973 Superbug. 1972 Volvo 144 in poo-brown.
    Not including hers...
  2. #82
    I'm guessing the TDI is different timing to the petrol as that was a long interval for changing belts.
  3. #83
    Dec 2008
    Sydney/Canberra
    Negative.
    All the same at 105K or 7 years.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
  4. #84
    Jul 2013
    Caulfield, VIC
    So I should disregard what I read about it being done at 160-180k clicks abd get it done asap at 118k?
    Sent from my HTC One X using Tapatalk
    www.TheRapidWrench.Melbourne
    The convenient, professional and affordable mobile bicycle mechanic that comes to you!
    My RS build thread
  5. #85
    Jan 2009
    Quote Originally Posted by woofy View Post
    In Europe, CR TDI engines also have a replacement interval of either 180 000 km or 210 000 km (depending on the engine code) with no time interval. For countries with high dust levels (e.g. Australia), the interval is reduced to 120 000 km.
    Nevertheless, the recommended replacement interval in Australia is 105 000 km/7 years.
    The belt is capable of lasting up to 180 000 km, but only in ideal operating conditions.
    Note that there is absolutely no reason why it cannot fail beforehand.
    The driving conditions and the operating environment in Australia, in most cases, would prevent the belt from reaching that interval without failing, hence the reduced replacement intervals.
    It remains up to the owner to decide when to replace the timing belt, but disregard the recommended replacement intervals at your own risk.
  6. #86
    Dec 2008
    Sydney/Canberra
    I've seen a few fail around the 130,000klm mark.
    I cringe when I read and hear that people are pushing close to that.
    '01 Beetle 2.0
  7. #87
    Jul 2013
    Caulfield, VIC
    Quote Originally Posted by Umai Naa!! View Post
    Sigh.. thanks for the last two replies. I'll get it done asap.
    My RS build thread
  8. #88
    Jul 2010
    the petrol tsi is chain driven...........
    MY17 Superb 162TSI, Business Grey, Tech+Comfort Pack, APR ECU+TCU Stg 1, SLA, Rieger Splitter + Side Skirts, Eibach Pro-Kit Springs, Hardrace Swaybar, TPMS
  9. #89
    Dec 2008
    Sydney/Canberra
    Quote Originally Posted by dArK5HaD0w View Post
    Early ones weren't.
    '01 Beetle 2.0
  10. #90
    Jul 2013
    Caulfield, VIC
    Ok, well theres no way I can afford to replace this **** right now. Im angered now because the money Ive had to spend on my Crewman just to sell it inflated like no tomorrow, I thought I was finally done with maintenance... And now the car is in for a wheel bearing, and looking at the blue smoke coming out. Im doing the cam follower tomorrow.
    So I found THIS DIY which, while it isn't easy at all, seems "easy enough". I think I can tackle it. I've had a play replacing the accessories pulley before so I've been down in that area.. its a start
    I've also found a Genuine kit on ebay HERE, but need to find one with a water pump as well, or get that separately.
    Do you guys have any words of wisdom/concerns before I go ahead with this? I will also get a quote to get it done, but it seems it will be at least $500-700 labour to even fit the ebay kit.....
    My RS build thread
