What's the weight difference including tyres? Heavy rims/tyres on the front will give you more axle tramping.
I have 18s on my Octavia wagon. I could have got 19s from new, indeed they were on the car at the dealers, but I thought the ride was very harsh with 19s. Now I am looking at some new wheels (VMR V701) in 19 inch and weighing up beauty vs utility. Bit like considering a new girlfriend! Ha ha.
What are opinions on 19s vs 18s? Mine is a work vehicle, will do about 25,000 km a year, mix of suburban and interstate.
19s for looks (subjectively), 18s for ride, performance, price, ie everything else.
Stick with 18s
get either 7.5" or 8" but get a slightly more aggressive offset
Buy something around 8kg.
I have the 19" on mine, and while it looks good, I hit a fairly shallow pothole a couple of weeks after delivery and damaged two tyres. I think the 18" with the higher profile would've had a bit more compliance.
.: MY15 Octavia vRS Wagon | 2.0T 162kw DSG | Moon White | Pano Roof | 19" Black Pack | Canton Audio + RVC :.
If you run 19s then you have to increase pressures to compensate for the lack of free volume within the tyre carcass.
18" tyres paid $690 for potenza s001 in 235 40 18 with 4 for 3 special.
a friend paid $1200 for potenza re003 in 235 35 19 with the same 4 for 3 special.
Sent from my GT-I9506 using Tapatalk
MINI Cooper S Clubman - FWD
i'm just checking if this is in relation to the tyre question or the potential girlfriend question?
on a serious note i changed from 18's to 19's and noticed a massive difference in ride comfort. that said it's probably ok for 80% of the time so up to you if you are prepared to suffer a bit over poor road surfaces...
