Page 5 of 6 FirstFirst ... 3456 LastLast
Results 41 to 50 of 53
Thread: Wheel spin followed by a bang?
  1. #41
    Dec 2012
    Sutherland Shire, Sydney
    Quote Originally Posted by Weekend-Warrior View Post
    Higher spring rates is usually the solution. For FWD more caster/anti-lift helps too.
    I now have the VWR springs and the supaloy control arms which have more caster
    These seem to have eliminated the axle tramp (more aggressive testing pending)
  2. #42
    Dec 2012
    I have now tried launch control and deliberately used too much throttle trying to promote axle tramp
    With the supaloy control arms there is no axle tramp at all
    The wheels just smoothly spin, traction control kicks in, grip re-established smoothly without any bang
    I'm rather pleased with this outcome...
  3. #43
    Jul 2011
    Burwood, VIC
    Quote Originally Posted by Martin View Post
    I've got the supaloys and when I rev over 2-2500 all it does is either false neutral or burn rubber
    ps. Martin I'm uber keen to hear your APR exhaust ... does it gurgle??
    - 2006 Audi B7 RS4 sedan, black, APR supercharged
    - 2008 Audi B7 RS4 avant, silver -- 2002 Audi B5 S4 vagwagon, ming blue
    - MY12 OCTAVIA vRS Wagon | DSG | revo | Eurojet DP | Milltek catback | KW V3's | 18x9 -45 Rays VR G2's | 18x8.5 -45 A8 Flat Fives | Kumho KU36 245/35 | Superpro ALK | ECS Stage 3 BBK | ECS eng mount | ITG Maxogen | DTM front splitter | SB
  4. #44
    Oct 2009
    Mitchelton, Qld
    So just for clarification, the supaloy control arms significantly reduce axle tramp and improve traction?
  5. #45
    Dec 2012
    Interesting - I did get a false neutral once and was perplexed by it
    On the outside it does have a faint burble
    On the inside the idle is a little louder but nothing cool or interesting
    The gas noises at wide open throttle are strange and add to the sensation of speed
    It's only the downpipe from the turbo to middle of the car - from there backwards it's stock
    (The down pipe does have a high flow catalyst)
  6. #46
    Feb 2010
    Camden NSW
    Hey Martin,
    where did you get these springs supplied and fitted?
    Thanks
    2018 Ralyee Green RS wagon. Fully optioned.
    Previous vehicles:2015 Volvo V60 Polestar (my one detour from VW/Skoda!)
    2013 Platin grey RS wagon / 2012 White Polo GTI / 2009 Black 125 Tiguan
  7. #47
    Dec 2012
    I got the work done at BWA Auto's in Seven hills - APR Agent
    They are porche/VW focused shop - lot's of history and experience
    They don't get to see most of their customers, the cars arrive on a truck
    First time I went there there was a old Octavia having the brakes worked on - all four corners
    And while I was there, three trucks turned up with Porche's to be worked on (2 street machines and 1 racer)
    If you have the time and a few tools you can eibach springs from UK (direct or via ebay)
    and fit them yourself and save a lot of money (VMR stuff is expensive)
    I was having a lot of work done so I got them to do it all
    http://www.ebay.com.au/itm/110910192...ht_2104wt_1015
    I will also say that I am now used to the firmer ride (initially it shocked me)
    It's just below the comfort level I prefer but feels great when you push it
    Have to be careful coming out of driveways - the tow bar smashes the ground more often now
    I would put a higher priority on the supaloy control arms - thay have made a significant improvement
  8. #48
    Dec 2012
    Quote Originally Posted by donweather View Post
    The supaloy control arms totally eliminate axle tramp but I would not say they improve traction
    If you give it too much on launch the wheels will easily and freely spin - need more throttle control and restraint
    The initial turn in is more precise and quicker (some improved feel until the power steering kicks in)
    The high speed (+180kmph) stability is also improved
  9. #49
    Feb 2010
    Camden NSW
    In theory only, of course....
  10. #50
    Dec 2012
    Quote Originally Posted by Tigger View Post
    Absolutely - that's just what was written on the packaging
