in my experience:
- Volkswagen Golf VI 2.0T > Engine > Mount > ES#2193007 Dogbone Mount Insert Kit - Red - 10-ECS-018R (best and cheapest)
- sticky tyres
- wider wheels
in my experience:
- sticky tyres
- wider wheels
- 2006 Audi B7 RS4 sedan, black, APR supercharged
- 2008 Audi B7 RS4 avant, silver -- 2002 Audi B5 S4 vagwagon, ming blue
- MY12 OCTAVIA vRS Wagon | DSG | revo | Eurojet DP | Milltek catback | KW V3's | 18x9 -45 Rays VR G2's | 18x8.5 -45 A8 Flat Fives | Kumho KU36 245/35 | Superpro ALK | ECS Stage 3 BBK | ECS eng mount | ITG Maxogen | DTM front splitter | SB
2012 Octavia vRS TDI. Darkside big turbo, 3bar tune, other stuff. 200kW/650Nm.
1990 Mk1 Cabrio. 1.9 IDI w/ 18PSI.
1985 Mazda T3500 adventuremobile. 1973 Superbug. 1972 Volvo 144 in poo-brown.
Not including hers...
[QUOTE=I've got some spare P-Plates in the boot, if you'd like... That being said, red ones would probably suit better. [/QUOTE]
reckon I need them hey??!!
wear my cap backwards too, while texting and reclining really far back in the seat too, with 'doof doof' music playing??
2018 Ralyee Green RS wagon. Fully optioned.
Previous vehicles:2015 Volvo V60 Polestar (my one detour from VW/Skoda!)
2013 Platin grey RS wagon / 2012 White Polo GTI / 2009 Black 125 Tiguan
I have a similar dog bone insert to firm up the motor - keen to see what it does if it causes intrusive cabin noise
Don't have sticky tires
I'm running 8" wide (compared to 7.5" stock)
Not loosing traction via controlled use of the gas peddle is what I'm doing to avoid the problem
whiteline have a similar void filler for the dogbone bush.
it works well, but at low rpm I can feel the motor more, and in reverse its worse.
that said, its manageable, and you just get used to it.
These mounts are for the connection between the transmission and subframe so doubt they do much for axle tramp.
Sticky tyres may not solve the problem.
Higher spring rates is usually the solution. For FWD more caster/anti-lift helps too.
And turn the TC off and use your right foot.
Also the so called launch control only works in S and manual with the TC off, not D.
