Results 1 to 10 of 21
Thread: Wheel Hub Spacers - anyone use them?
    Dec 2008
    I'm ordering spacers for the rears (20mm) anyone using them at the moment?
    MY13GOLF2.0GTI/6SPDMAN/CARBONSTEEL
    MY15TIGUAN2.0TSI/DSG/WHITE
    Jun 2009
    No, they are illegal to use on road registered vehicles unless supplied by factory.
    Also i have heard of some of the cheaper ones fracturing.
    Mar 2013
    Brisbane QLD
    yep.. illegal...even tho ive seen some cars with them on..told the customer and they didnt know.. when the rims were fitted at a proper shop they put them on!!
    VOLKSWAGEN TECHNICIAN - 16 YEARS OF PAIN..
    VCDS CODING- FAULT DIAGNOSIS - PRE PURCHASE INSPECTIONS- REPAIRS
    9W2 BT KITS -$300 - 9W7 BT KITS - $450 - CANBUS UPGRADE $150
    BRISBANE / GOLD COAST
    Bowral, NSW
    I'm considering getting 10mm spacers... especially for the rears on mine.
    I know about the legalities, but for 5-10mm? Really?... My cars a bit of a legal anomally anyway
    2012 Octavia vRS TDI. Darkside big turbo, 3bar tune, other stuff. 200kW/650Nm.
    1990 Mk1 Cabrio. 1.9 IDI w/ 18PSI.
    1985 Mazda T3500 adventuremobile. 1973 Superbug. 1972 Volvo 144 in poo-brown.
    Not including hers...
    Pacific Paradise QLD
    Quote Originally Posted by Mysticality View Post
    Far better to get wider rims or a wider profile tyre and be safe 10mm is hardly worth while anyway
    Jun 2007
    Eastern Suburbs Melbourne
    Yes, they're illegal in Australia. (What isn't these days?)
    If they're TUV (etc) approved, I wouldn't bat an eye lid.
    Just make sure you use longer bolts, and as mentioned before, don't get cheapies.
    i like volkswagens
    Jun 2009
    My thoughts exactly.
    For the cost of a set of 4 quality spacers you could just get a better set of wheels that actually fit with the correct width and offset without the legal issues.
    Bowral, NSW
    I've got 18x7.5's with 235/40R18's on them... They don't make my rims in a wider size. If they did, I'd be all over that.
    Jun 2011
    Sydney NSW
    The spacer puts additional bending loads on the studs/bolts. Your studs/bolts also need to be longer by at least the thickness of the spacer, otherwise you are not getting the same amount of thread engagement.
    5 or 10 mm might not seem much but the steering offset is generally +/- 25 mm (depending on whether you have a negative or positive offset. A 10 mm spacer can easily change that offset significantly and change the way it responds to steering input. You don't have steering offset issues on the rear, but you do have increased bending loads on studs/bolts.
    This is much like what Ford Escort and Capri owners would do to their cars. They used to use longer spring shackles for the rear leaf springs so that it gave the car a "nose down" appearance. It did that, but also took all the caster out of the steering. Not a problem at city driving speeds, but on the open highway, the car would be extremely unstable.
    If you want a wider track, then the way to do it is with wheels that have the appropriate offset.
    Gosford Central Coast NSW
    I think its way too much of a generalisation to say spacers are dangerous. Spacers are not dangerous - but some spacers are cheaply made and may crack, and if you use spacers with incorrect bolts well you are asking for trouble.
    People have been using spacers on the race track for eons, (where the loads are far higher than on the road) and some manufacturers have used crazy spacers (I'm looking at you Porsche!!!) on factory cars aswell.
    As far as the engineering goes, a properly fitting spacer with appropriately long bolts is just as safe as anything else. (Trust me, Im a gingerbeer.... i mean engineer).
    But yes its still illegal unless engineered.
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
