Originally Posted by
brad
Hillbilly, if I can move mine 8kph by going up 20mm in diameter (which is still illegal) then why do you need 40mm to move the same approximate error? What am I missing?
Well according to the comparator I posted a 195/55/15 has a diameter of 595mm on a 5.5in rim
To get a 6.7% difference I would have to go to a 195/65/15 which has a diameter of 635mm. Diff is 40mm
Remembering the diameter is right across widest point and not the radius which is from the centre to one edge. In QLD 26mm is largest legal diameter difference
Put the figures in the comparator with the larger size on the left and you will see.
Mamba Ebike to replace Tiguan
