That's exactly who I bought them from today. But I completely forgot to ask if they were 92Y. I hope they are!!!
Edit: just checked they're website. 92Y. Lucky!!
Tyre Search, Goodyear Autocare, Australia
Harlie - you need to know how far wrong your speedo is at the moment before you make changes
DUBGTI let me know if you want to test your speedo. I have a GPS speedo in my possession at the moment.
Tyre shop is correct on both counts (but I agree with Brad's advice, check it out before playing is preferable).
8mm larger diameter, which means you will be going a fraction slower than indicated. 235/40/18s are often cheaper than 225s as the 235s are a common Falcodore 18 inch fitment and thus bought in large quantities.
Loads of wheel options, check out the Mk7 thread if you like as plenty of 18x8 ET45 or similar wheels in there.
Octavia vRS TDi DSG MY10 - RD Technik tuned
Polo 9N3 1.9TDi
18x8 ET45 235/40R18 will fit FINE if you get the inside of the rear guards cut out. (easy job, 5min with a dremel)
Zei20t's wheels, IMO, will NOT fit (19x8.5 235/35R19) once he's lowered. He's at stock height at the moment which is a massive difference as far as clearance is concerned.
18x8 ET45 245/40R18 *may* fit, I'm yet to test this though.
2012 Octavia vRS TDI. Darkside big turbo, 3bar tune, other stuff. 200kW/650Nm.
1990 Mk1 Cabrio. 1.9 IDI w/ 18PSI.
1985 Mazda T3500 adventuremobile. 1973 Superbug. 1972 Volvo 144 in poo-brown.
Not including hers...
In fact ALL car speedos must read over the speed you are actually doing and legally cannot read less.
The ADR rule states that they may be up to 10k over at 100kph <> 4 so they could be up to 14k fast but are not allowed to read under.
Putting larger tyres on makes it read slower but in my case in the Polo it is 7k over and to get it right would take tyres 40mm larger which are illegal
See here for accurate alterations Custom rims, wheel tire packages for your ride - RIMSnTIRES.com
Well according to the comparator I posted a 195/55/15 has a diameter of 595mm on a 5.5in rim
To get a 6.7% difference I would have to go to a 195/65/15 which has a diameter of 635mm. Diff is 40mm
Remembering the diameter is right across widest point and not the radius which is from the centre to one edge. In QLD 26mm is largest legal diameter difference
Put the figures in the comparator with the larger size on the left and you will see.
