Results 11 to 20 of 22
Thread: What are the quietist Tyres for an Ocatvia RS
    Erskineville, NSW
    Quote Originally Posted by dArK5HaD0w View Post
    even yokohama mention in their pdf, from the link above, that the min. rim size required for 235/40/18 is an 8" rim.
    the rs neptunes r 7.5".
    That's why I added the "though"
    Jul 2010
    yup.....i realise that
    i was merely stressing my disappointment in that 235s aren't recommended on a 7.5" rim.
    the last thing i wanna do is put them on, cause it's possible, but have insurance ping me if something were to go wrong
    MY17 Superb 162TSI, Business Grey, Tech+Comfort Pack, APR ECU+TCU Stg 1, SLA, Rieger Splitter + Side Skirts, Eibach Pro-Kit Springs, Hardrace Swaybar, TPMS
    I think the dBs will be pretty sub par compared to the stock tyres. I'd be looking at the s drives or advans for Yokohamas..
    Jul 2009
    Quote Originally Posted by woofy View Post
    Nevermind, just remembered you got the oversized PS3s....
    And what effect will that have on the noise? The 235 tyres are legal from a Vicroads and insurance perspective (the insurance said as long as Vicroads are happy, so are they). So drop it............
    Octavia vRS Tractor Motor DSG Kombi
    Erskineville, NSW
    Kumho KU27 would be worth a look if you are on a budget. Tempe Tyre or Option1 would be the best places to get a price from.
    May 2011
    Riverside, Tasmania
    Hi Brad
    Thanks for that I think we have settled for the v500's. and the size is right.
    If you get the correct specs for a 2009 2.0TDI RS wagon that would be a real help, as VW treat it like a state secret.
    Many thanks - John
    I don't think the Yokohama db comes in the right size for the RS. 225/40x18 isn't it?
    Toyo Teo are quiet - 235/40x18 though.
    I thought the CSC2 on my Elegance were bloody noisy - especially when they got below 50%. Now running Michelin Primacy & they are much better. For you, the Michelin PS2, Goodyear Eagle F1 or Pirelli PZero might be worth a look. Truly, almost anything will be better than the Dunlops.
    My best mate in NZ does wheel alignments for a living - do you want me to ask him what the factory specs are& what he would set it to? It isn't rocket surgery - even I can set a car up based on the tyre wear patterns.
    jbee - seriously, your better off importing from tirerack.
    edit: does Tassie still have all those crap course-chip roads? They will make any tyre/car noisy.
    May 2011
    Riverside, Tasmania
    Hi Everyone - thanks for the suggestions and ideas, I think we will go for the V550dB's and a good wheel aligner and see how it goes.
    Cheers - John
    Quote Originally Posted by Ocy_RS_TDi_Kombi View Post
    I actually had asked about what you paid for the PS3s then remembered you got the bigger size..so edited it...I probably should have just deleted it, but didn't it, so I think you took it as meaning something else.
    Just to check, I've got the Zenith tyres which from memory are 7.5" and those tyres are minimum 8", I have had the same issues with my previous cars as mazda run narrow alloys as well. Technically the 225s are only just meeting the spec (min 7.5", recommended 8")...so surprised the tyre guys fitted 235s, they are legal for the 18" size, but not in respect to the width. Most tyre places won't fit them for that reason. I don't know if the Neptunes are 7.5 or 8" though.
    Erskineville, NSW
    Quote Originally Posted by jbee View Post
    Hi Brad
    I'm not sure what happened - I'm sure I posted the info the other day. Anyway, I'll try again.
    A summary of his emails to me. The guy has been doing wheel alignments for 30 years.
    • the specs are only a guide & 80% of cars I set outside of specs ( it s real easy to change the spec s to make them look like they are factory on the printout summary )
    • for some reason the europeans still persist with front toe out on their front wheel drivers which is crap as alot of these cars run negative camber as well so you end up with boatloads of inside wear
    front (machine specs)
    Camber: -0.68deg +-0.50deg
    Caster: 7.78deg +-0.50
    Toe: 1.1mm +-1.1mm
    Cross camber: 0 +-0.50
    Cross caster: 0 +-0.50
    Total Toe: 2.1mm +-2.1mm
    His notes:
    A fraction less -ve camber &/or caster on the RHS isn't a bad thing - helps it steer straight on a cambered road.
    If the front camber is anything greater than -0.75 then go for maximum toe-in. I'd go up to 5mm depending on tyre wear & what the current setting is.
    rear (machine specs)
    Camber: -1.75deg +-0.50deg
    Toe: 1.1mm +-1.1mm
    Cross camber: 0 +-0.50deg
    Thrust angle: 0 +-0.33deg
    his notes:
    Depending on tyre wear & previous settings, this would be a classic case of giving the car more toe-in on the rear & reducing -ve camber if possible.
    If rear camber is greater than -1.0deg then I'd be aiming for about 6mm total toe-in, then take the car for a drive at speed & swerve from side-to-side to make sure the rear end isn't oversteering the car.
    none of the above is rocket surgery. Any good/experienced wheel aligner looks at the old tyres wear pattern & adjusts to suit. I always prefered to have my customers bring in their car with the old tyres on, do the alignment & then get the new tyres fitted & do any minor adjustments after that (to get the steering wheel straight). If your alignment guy doesn't want to see the old tyre wear patterns then he probably isn't that good & just blindly follows the spec book.
    Jun 2009
    Northfield, Adelaide
    Was having some inside feathering on the rears on my 09 RS TDI Wagon, and had a good chat with the guys I take my Skoda to about wheel alignmentand what i wanted from the vehicle. I told them the kind of driving i do and how often i load the back up etc and they adjusted to suit what i wanted in the end.
    But what's interesting is what Brad has said with the Specs.......I'm not disputing what he said or 30 years of experience but what I've found is a Rear-wheel drive vehicle "pushes" the front tires, as they roll along the road, resistance causes some drag resulting in rearward movement of the suspension arms against their bushings. Most rear-wheel drive vehicles use positive toe to compensate for suspension movement.
    But Front-wheel drive vehicle "pulls" the vehicle, resulting in forward movement of the suspension arms against their bushings. Most front-wheel drive vehicles use negative toe to compensate for suspension movement.
    Obviously there is handling characteristics to take into consideration as well - depending on what kind of driving you do etc
    I have the "degrees-Minutes" measurements for my Front wheel drive 09 RS TDI Wagon in stock suspension trim
    This is the Specs i have
    Front:
    Ride Height: 366mm to 386mm
    Camber: -1deg 11min to -0deg 11min
    Caster: 7deg 17min to 8deg 17min
    Toe: 0deg 0min to 0deg 10min
    Cross Camber: -0deg 30min to 0deg 30min
    Cross Caster: -0deg 30min to 0deg 30min
    Total Toe: 0deg 0min to 0deg 20min
    Rear:
    Ride Height : 370-390mm
    Camber: -2deg 15min to -1deg 15min
    Thrust angle: -0deg 20min to 0deg 20min
    Not sure if people also want the SAI & Included Angle measurements?? These aren't adjustable but help diagnose bent steering/suspension parts
    For the rear feathering problem i had the rear camber set as close to the least -ve limit ( -1deg 15min ) so when the back is loaded up ( which it is for those long haul trips ) then as it's weighed down the the rear -ve camber increases then the inside of the tyre wont be loaded up as much as if it was already set to a higher -ve........ does that make sense to people??
    Anyway I hope that helps people a little??
