Page 54 of 96 FirstFirst ... 444525354555664 ... LastLast
Results 531 to 540 of 957
Thread: What did you do to your Octavia today?
  1. #531
    Feb 2009
    Any learns from the tensioner replacement?
    I was thinking of doing this proactively at 75,000 even without a rattle....
  2. #532
    Dec 2012
    Sutherland Shire, Sydney
    Quote Originally Posted by code618 View Post
    I learnt a few things
    My car is a Nov 2011 vRS - it had the early model tensioner
    It was out at it's maximum adjustment - the new version seems to have a longer rod and range
    When replacing the tensioner ($120) the plastic timing chain cover ($300) is also replaced (don't know why)
    If you get the rattle and are under warranty you should be in a position to get it fixed for free
  3. #533
    ^ the timing chain cover is a very thin metal - not plastic. It is known to warp/bend when removing, which can cause leaks if you reuse it - which is why they recommend replacing it.
  4. #534
    Apr 2015
    Five Dock, NSW
    New plugs installed. Wow! What a difference. Old ones were very worn. Now running much more smoothly, and efficiently. 👍🏼💥
    36mm socket purchased so I can do an oil / filter change too.
  5. #535
    Washed mine on the weekend...
    Took it in today for firmer of rear brakes (fronts already done), and some troubleshooting: airbag light is still on, and the fuel guage is failing (irrespective of fuel level) intermittently; somewhat ironically, only ever when I'm pulling into a servo! Lol!
    No battle plan ever survives contact with the enemy
  6. #536
    Oct 2009
    Mitchelton, Qld
    Quote Originally Posted by Smiley_Walsh View Post
    New plugs installed. Wow! What a difference. Old ones were very worn. Now running much more smoothly, and efficiently. ������
    How old (kms) were your old plugs?
  7. #537
    Got mine back with rear brakes fitted: all good!
    However.... After scanning for fault codes, it appears a number of issues have been logged: short story: it appears I have CANBUS issues... *sigh*
    The car was cheap enough to purchase that it's not a major issue for me, but I want it running right. Guess I'll book it in at Skoda to diagnose the exact cause. It's all niggly things like the intermittent fuel guage failure, etc.
  8. #538
    Oct 2009
    Mitchelton, Qld
    Sunday:
    Finally gave her a very much needed wash.....and typical, it's now rained in Brisbane since Sunday!!!!
    What did you do to your Octavia today?-img_1407-jpg
  9. #539
    Erskineville, NSW
    Quote Originally Posted by MickeyB View Post
    Where are you?
    It might be better to go to an independent.
    If it's the actual canbus then it's not a big deal.
  10. #540
    I'm located on the Gold Coast: happy for any suggestions regarding someone reliable to take a look: I'm new to VAG vehicles, so please feel free to guide me!
