Page 45 of 96 FirstFirst ... 3543444546475595 ... LastLast
Results 441 to 450 of 957
Thread: What did you do to your Octavia today?
  1. #441
    Erskineville, NSW
    Quote Originally Posted by GeeMatt View Post
    Same same. My 22 year old son had to be coaxed into driving. Had his learners but couldn't be bothered. Only way we got him over the line was to buy him a car and make him drive it. Mind you I am using it as MY project !
    Still catches the bus to uni ! Lots of similar stories in his group.
    Not driving to Uni makes a lot of sense as there is never any parking.
    Gerrycan - I agree, the public transport in London is fantastic.
    I'll admit a certain level of selfishness in wanting her to drive. She doesn't drink alcohol (various reasons which is fine by me), so it would be good if she could drive home and give me the option of having an extra drink... or 3.
  2. #442
    Sep 2011
    SA
    Well not today but over the weekend...
    Fitted new plugs, timing belt inc new tensioner and idlers, new water pump, new PCV, flushed coolant, new air filter, sway bar bushes, ball joints, lower control arm console bushes, lower control arm inner bushes (all superpro) traced a rattle in the dash to a stray $2.50 in coins floating around, washed and waxed, treated the leather, installed FL climate control and Swing radio I had laying around from a previous project... then I had a rest!
    Next weekend is new strut mounts and bearings as well as Bilstein B4's all round (I'm too old for B6's or B8's) I also have a Mk5 GTI MFSW to go on, just changing the SMD leds to green ones at the moment... also fitting the required highline controller to make it work. Following that I'll be splashing out on a later CANBUS and Columbus headunit and OEM bluetooth.
    Last but not least I'll also be fitting a new HPFP cam follower and changing the oil and filter but that will probably be the weekend after.
    PS car is a 2008 VRS 2.0 tfsi
  3. #443
    May 2014
    ACT
    Had to use the fog lights today.... Typical winters morning in the nations capital
    SOLD 2006 VW Golf Comfortline 1.9TDI | DSG | Metallic Grey | Stock
    2015 Skoda Octavia Ambition Plus 103TSI wagon
    SAHM
  4. #444
    Apr 2009
    Northern Tasmania
    Put a new indicator switch ($31.39 eBay from China) in to fix the dead cruise control. Lucky I'd previously replaced the steering column and knew the tricks to getting the bits behind the steering wheel off. I almost always left the little cruise control switch on top switched on - maybe that was not a good idea, but I would have thought moving it off and on would wear it out quicker.
    Finally got around to installing my front Koni FSD struts and the front H&R anti roll bar to go with the rear ones - and a set of alloy SuperPro lower control arms with bushes, and a Superpro torque arm insert (stiffens up the lower rear engine mount). Still have the standard springs - I'm not interested in lowering it.
    Blimey what a difference! Bit hard to tell what did it, but the alloy control arms are 2.3 kg verses 3.95 kg for the steel ones, so less unsprung weight combined with the excellent FSD struts/shocks. The ride is much more comfy. Worth the $930 for the FSD's. Now it rides/handles as good as it goes.
    2008 Skoda Octavia Elegance TDI 4x4 wagon
    Bluefin 132Kw/385Nm, Racechips Response Control, Haldex Performance controller, H&R anti roll bars, Koni FSD shocks, SuperPro control arms & ball joints, subframe & gearshift mods, Full Dynamat interior, Polk Audio sound, Columbus, Bluetooth, MDI, parking sensors, camera. BBS SR 18x8" w/ 225/40xR18. 3M Crystalline tint.
  5. #445
    May 2014
    ACT
    Cleaned the car, inside and out (over 2 days), but didn't do the wheels as I didn't have time. Looks good What did you do to your Octavia today? .
    Finally installed the rearguard! Was looking at the instructions and it states the best temp range to install it is 18-30 degrees. If I was going to wait for the weather to warm up, I'd be waiting months, lol!
    So with a clean car, hair dryer, masking tape and numb fingers, I attached the guard. Looks fantastic (IMO).
    Ps. That's the Aldi bootliner that is dirty - original is nice and clean What did you do to your Octavia today? .
    What did you do to your Octavia today?-uploadfromtaptalk1436071283765-jpgWhat did you do to your Octavia today?-uploadfromtaptalk1436071331568-jpgWhat did you do to your Octavia today?-uploadfromtaptalk1436071374404-jpg
    SAHM
  6. #446
    Oct 2009
    Mitchelton, Qld
    Gee it blends in great. Hardly even notice it's there.
  7. #447
    Oct 2009
    Mitchelton, Qld
    Man the vRS is absolutely loving these cold mornings. I swear there's another 10kW or so at the wheel with the cool crisp mornings.
  8. #448
    Erskineville, NSW
    Quote Originally Posted by donweather View Post
    I wouldn't mind but my fuel usage takes a hit every winter.
  9. #449
    Mar 2014
    Melbourne, Victoria
    They are built for this weather. The turbo and engine absolutely loves the cold air flow. I've also noticed that the engine has stepped up a notch in performance in the last few days, and the only anomaly I can think of is the Melbourne weather.
    I'm guilty of milking every bit of this sudden mechanical enthusiasm! It means more stops at the pump though.
    Walking Contradiction...
    MY15 Skoda Octavia vRS 162 Race Blue Combi
  10. #450
    Apr 2012
    Upper North Shore,NSW
    Quote Originally Posted by daMama View Post
    Beauty of a grey car, add ons blend in much better, my white car is another story....
