Page 43 of 96 FirstFirst ... 3341424344455393 ... LastLast
Results 421 to 430 of 957
Thread: What did you do to your Octavia today?
  1. #421
    Erskineville, NSW
    Quote Originally Posted by ozgti View Post
    Will the mk7 r Springs fit a mk3 rs wagon?
    I don't know. The R is AWD, the RS is FWD and there are some differences in the back end mechanicals. You'd have to ask the spring manufacturers if there's much of a difference in the spring perches. Probably the easiest way is to look at the partnos offered by the coilover suppliers to see if they are the same
    Keep in mind the R is a lot lighter in the tail than an RS so you will get some lows - esp with a load on board. Maybe wait for the R-wagon and use springs off that?
  2. #422
    Apr 2008
    Western Sydney
    These are the ones you want and fully compatible with the RS. Different springs for R and GTI. Best get in contact you find which are more suited to the RS Sport Springs (ACC compatible) - Volkswagen Racing
  3. #423
    Oct 2009
    Mitchelton, Qld
    Quote Originally Posted by Dzl_Dubba View Post
    As Brad alluded to above, isn't the RS (particularly the Wagon/Combi) heavier than the Golf, thus are those springs you've said above 100% compatible with the RS?
  4. #424
    Apr 2008
    Western Sydney
    Quote Originally Posted by donweather View Post
    It states in the compatibility list the springs are compatible with the Octavia RS. Which set it doesn't say. Best ask the manufacturer.
  5. #425
    Erskineville, NSW
    Mechanically they'd fit but I reckon it would have a droopy bum as the VWR partno is the same for all MQB platform vehicles.
    If you look at the Eibach cattledog the R has a partno is
    E10-85-041-01-22 (black spring pro-kit) with a 10-15mm drop front & rear. The axle loads are 1100kg F / 960kg R.
    For the RS TSI & TDI wagon AND hatch the partno is
    E10-79-010-02-22 (pro-kit) with a 20mm F / 10mm R drop. Axle loads are 1070 F/ 1075 R.
    or
    E20-15-021-05-22 (red Sportline) with 25-30mm F / 25mm R drop and 1070 F / 1050 R axle loads
    If you look in the Eibach catalogue the individual springs have a link to the Allgemeine Betriebsurlaubnis (german certificate of conformance???). It gives the (excuse spelling and the English isn't a translation - just what I know it is) Dractdurchmesser (wire diameter) in mm; the ungespannt federlange (wire length) and the gesamptwindunszahl (number of coils - I assume it's total so subtract 2 for # active coils) & the ausfurungbezeichnung (partno).
    You can use this to calculate the spring rates (assuming all the steel has the same heat treatment). (you have to guess at some dimensions but you leave these as constants)
    Spring Calculator
  6. #426
    Apr 2008
    Western Sydney
    This can be resolved if you just get KW coilovers
  7. #427
    Feb 2009
    NSW
    Don't want coilovers.. Too harsh
  8. #428
    Erskineville, NSW
    Not if you get the right ones with a decent spring rate.
  9. #429
    Glen Waverley, VIC
    +1. Gotta pay to play.
    Mine: Octavia vRS Combi (MY15) | Brilliant Silver | 6MT | 162Kw 350Nm | Tech Pack* | 18" Black Pack | Leather | Sky Port | Ordered Aug 14 | Built Wk 48 2014 | Landed 3/2/2015 | Delivered 20/2/2015
    Hers: MY06 MkV Golf TDI 6DSG | Silver | Stock | RNS510 + Badge RVC Installed.
    Weekender/Project:
    Classic Mini 1972
    Dependant #2: Mk4 2001 GTi
  10. #430
    Mar 2015
    Kellyville Ridge, NSW
    Red face
    Genuine Skoda Octavia Plastic Boot Dish (5E5061162).
    Genuine Skoda Octavia Heavy Duty Rubber Floor Mats (5E2061550).
    The plastic boot dish fits perfectly in the boot and helps protect against spillages and dirt. It's about 100mm deep.
    The heavy duty floor mats also fit perfectly and are a very snug fit. I put them on top of the carpet floor mats for that extra sound deadening.
    Attached Thumbnails Attached Thumbnails What did you do to your Octavia today?-20150612_121524-jpg
    MY15 VW Golf R | White | Manual
    MY15 Skoda Octavia RS 162TSI | Liftback | Race Blue | DSG | Tech Pack (w/o RVC) | +2 Years Extended WarrantySOLD
