Page 48 of 96 FirstFirst ... 38464748495058 ... LastLast
Results 471 to 480 of 957
Thread: What did you do to your Octavia today?
  1. #471
    Jul 2014
    Quote Originally Posted by 99Reza View Post
    Bought some acoustic underlay to line the boot area with, 1.8sqm should be enough for the job, I hope. I also have heaps of dunlop carpet underlay from previous carpet job at the house, will use this quite extensively . Still waiting for the actual deadener to arrive...
    I would be interested to hear how that goes. Lots have done it but you rarely hear any subsequent "OMG better than a RR now" type comments.
    Naturally I expect pre and post installation noise meter readings
    Well an app on mobile phone will do.
  2. #472
    Sep 2010
    QLD
    My sound deadener has arrived, it's not Dynamat Extreme but I was on a budget , $70 bucks including shipping for 1.95sqm.
    What did you do to your Octavia today?-20150818_125209-jpg
    Total spent for this project is $159 for anti-drum (deadening), insulation foam and install kit.
    Inspected the boot area for plan of attack and little bit of vacuuming as well, the problem that I can immediately hear is the area right behind the rear seat. Skoda has 'generously' included a layer of sound deadening for that particular area, however bang it with your fist and it sounded very similar to a drum , a rather loud one. I managed to muffle it by sitting on top of it lol.
    I've used Dynamat Extreme in the past and RAAMat as well, if you have the budget stick with Dynamat Extreme, they are the best. The foil on the Dynamat is very thick and can easily do a lot of damage to any of your flesh, plus the black stuff will stick to EVERYTHING, clean or dirty.
    The one I just bought from for the Octy has a very similar feel to RAAmat, perhaps slightly stiffer. Hopefully it will do the job as our car is pretty decent to start with.
    I've downloaded db meter app for my android phone , will let you know the result.
    2011 Tiguan 125TSI - SOLD
    2014 Race Blue Octavia RS 162TSI Combi
    Check out my leather work ----> http://pedsnro.blogspot.com/
  3. #473
    Apr 2012
    Upper North Shore,NSW
    Will be awesome if you can include some pics too. I am looking forward to do some deadening as well, only for the boots though.
  4. #474
    Sep 2010
    QLD
    Quote Originally Posted by sillyboy View Post
    I'm only doing the boot area as well, for now at least. It will be good to do the doors, especially the door skin, I find them shockingly flimsy
  5. #475
    Oct 2010
    I will get around to sound deadening the boot and front doors. I have heard there are airbag sensors in the front doors, somight want to check before you pull trims off. Take some pics when you do it all!
  6. #476
    Sep 2010
    QLD
    Played around with the decibel meter this afternoon, baseline reading at idle in the garage is around about 40db. Driving around at local road at speed of 50km/h resulted in a reading of around about 59-61db dependant on road surface.
    I also managed to lay down some deadening in the boot area, two layers directly behind the rear seat and patches inside the spare wheels well.
    What did you do to your Octavia today?-20150818_190935-jpg
    I wasn't expecting any reduction in road noise which is confirmed with the decibel meter, however whenever the car encounters road imperfections (bump, pothole, etc) I found that the interior noise to be less peaky, this is an encouraging result . I will add some more deadening in the wheel well and around the boot area, probably two sheets max. Hoping to get a better result once the the acoustic liner is laid down
    GTR27: On my younger days, I often pulled apart the door skin on my car (Merc C-class w203) to tweak the sound systems, they have an actual airbag in the door and it was a pretty ordinary experience, no sensor was faulted AFAIK. I was never involved in an accident with that car though, so can't comment on the integrity of the sensor itself .
  7. #477
    Erskineville, NSW
    Add the sound deadener under the passenger seat
  8. #478
    Jul 2010
    this is my attempt at sound deadening the boot area......
    mirrored the same for the left side.
    i'm tempted to put some sound deadening carpet under the parcel shelf too.......
    MY17 Superb 162TSI, Business Grey, Tech+Comfort Pack, APR ECU+TCU Stg 1, SLA, Rieger Splitter + Side Skirts, Eibach Pro-Kit Springs, Hardrace Swaybar, TPMS
  9. #479
    Sep 2010
    QLD
    Any pointer on removing the rear seat?
    Quote Originally Posted by dArK5HaD0w View Post
    I think I'm going to follow your application pattern, is your car noticeably quieter with the deadener? do you put anything else on top of the deadener?
    I did more measurement today whilst driving on the highway, result as follow:
    • 80km/h - 64 to 65 db
    • 100km/h - 66 to 67 db
    This is done while cruising with minimal engine load. Road surface is quite smooth.
    Just for fun, I did test my C-class, at idle it read 43 db and same db reading at 80km/h. Skoda is doing a pretty good job me think
  10. #480
    Erskineville, NSW
    I'm not sure about a Mk3 but on a MK2 they hinge at the front so you grab the back & lift
