Mine: Octavia vRS Combi (MY15) | Brilliant Silver | 6MT | 162Kw 350Nm | Tech Pack* | 18" Black Pack | Leather | Sky Port | Ordered Aug 14 | Built Wk 48 2014 | Landed 3/2/2015 | Delivered 20/2/2015
Hers: MY06 MkV Golf TDI 6DSG | Silver | Stock | RNS510 + Badge RVC Installed.
Weekender/Project: Classic Mini 1972 Dependant #2: Mk4 2001 GTi
2014 Skoda Ambition Plus 103TSI candy white wagon, 6sp Manual, Tech pack, Panoramic Sunroof, 18's, Colour Maxidot, Comfort BT
Ordered 07 May 14 (Wk 15), Built Wk 37, Loaded 27/9 (wk 39), Docked 12/11 (wk 46), DELIVERED! 12/12 (end of wk 50 - 7 months + 1 week).
Even with a resistor it would run the battery down.
Yeah when I get in, fuel pump prime is noticeable.
the mk2 does the same thing.
only happens when the drivers door is opened.
MY17 Superb 162TSI, Business Grey, Tech+Comfort Pack, APR ECU+TCU Stg 1, SLA, Rieger Splitter + Side Skirts, Eibach Pro-Kit Springs, Hardrace Swaybar, TPMS
If there is a residual current flowing through the map lights then it surely it won't make any difference whether the bulb is LED or incandescent.
The voltage is probably too low to light the filament on the incandescent, but can just support an non-resistor LED.
The interior lights or not simple on/off but attached to a fade up/down system, so maybe yours (or anyone's?) does not entirely switch off when it fades down?
It might also be a 'feature'. Failed exterior bulbs can be detected even when switched off so there must be some residual current allowed through to detect any failure.
Basically I am saying that any drain will probably be minimal and you may as well put the LEDs in having bought them, or at least check with the dealer if there is a problem.
