VRS Wagon on Eibach Springs?
Originally Posted by
Kieral
Not meaning to hijack a thread but anyone running the 20mm eibach springs on the mk3 Wagon? On the stock shocks?
Yes, have just done mine
Here is the report I did on Skodamodderz Facebook page - you should join us if not there already
Well after spending a few hundred k’s in the car today I can confirm that the ride is firmer as expected, small bump compliance is still there and the larger bumps are still dealt with easily.
The car sits noticeably flatter in corners and the steering is now much more direct (I do have an aftermarket sway bar also set to its firmest setting)
Ride height - the car has settled evenly all around with the front dropping 25mm and the rear 10mm giving an even 2 finger gap all around
I understand the Sportline kit gives approximately another 10mm all around, but with the 35k I spend a year in the car for work it needed to remain comfortable & practical
The build quality and finish of the Eibach springs is worlds apart from the previous numbers of King’s & Pedder’s springs I have fitted. They are an exact match and fit to factory mounting points and even come with a shortened bump stop for the front struts
Car also has spacers fitted 40mm rear 30mm front so my wheels do fill the guards correctly
MY16 Octavia VRS Wagon, DSG, Race blue, Tech pack, Comfort pack, Black Pack, 19's, Sunroof, Electric Tailgate
Airbox mod, VW Racing Filter, TMD, Elbow, Ramair Pipe, GFB DV+, VCDS mods, Superpro adjustable rear sway bar, Superpro end links, Whiteline front sway bar links, Whiteline LCA bush Kit, Bilstein B14 coilovers, HPA dog bone mount & arm, 42DD oil catch can, Burger wheel spacers, CTS downpipe 200 cel cat, 2,5" exhaust , twin out. Super Skoda eyelids & front splitter, Tuned by BPS 228kw atw, Dsg tune,
