Originally Posted by
dArK5HaD0w
+1.
i don't understand the 80km/h limit as its a "full sized" tyre.
it has the proper load rating.
it has the appropriate speed rating.
its ur regular tyre.
the 16" has the same rolling circumference as the 18" tyre. so they will b "rotating" at the same speed as the 18s.
+2
You may need to slow down a bit for corners but in a straight line, the narrower tyres should be fine to drive at the full speed limit.
Mysticality
I don't have a second jack to allow me to swap them, else I would have already. :/
The idea is to change the rear to the spare first and then put the former rear to the flat front.
Resident grumpy old fart
