I understand why the ECU is flashed, but is there a way to tell. Not having driven a GTI or VRS before i have no base line for performance.
Will see what the mechanic says, either way i hope its an easy fix
No, coil pack failure has much larger impact and symptoms, you would not be driving it around with coil pack failure.
(Flashing the ECU is done for more power - APR, Recode, etc)
if somebody is driving behind you a black haze from the exhaust, especially during the gear change, is an indication of a tuned/flashed ECU
Otherwise, without a benchmark a stage 1 tune may not be obvious (a stage 2 tune is fairly obvious as it's rather aggressive)
Ok, so got it fixed.
It was cylinder 3 coil pack.
Drives great now. Andrew at Volkservice was very helpful and fast.
Thanks for all your help guys
Great to hear on both fronts. I swapped my coil packs for the red top ones, going to get some logging done but I suspect my tune doesn't play well with the DSG since it's fine in S mode and when shifting manually...
Yep, coil packs often go...
And it is usually number 3!
Replace them with Audi R8 coil packs. Much stronger, and more reliable.
Straight swap
2018 Ralyee Green RS wagon. Fully optioned.
Previous vehicles:2015 Volvo V60 Polestar (my one detour from VW/Skoda!)
2013 Platin grey RS wagon / 2012 White Polo GTI / 2009 Black 125 Tiguan
